ᐅ How can I professionally and evenly paint Ikea BESTA fronts?
Created on: 21 Jun 2023 08:27
Sauru
Sauru
21 Jun 2023 08:27
I’m planning to repaint my Ikea Besta fronts and want to achieve a truly professional and even finish. So far, I have only painted furniture in a basic way, but never specifically Besta fronts, which are often made of coated or melamine resin-coated material.
My specific question is:
How do I best prepare the surfaces, which type of paint is most suitable for durable, resistant fronts, and how can I ensure the paint finish is really even—without runs, bubbles, or uneven joints?
Are there any particular techniques or tools that are especially recommended for these types of fronts?
I have considered spray paints but have no experience with them.
Thanks in advance for your tips and experiences!
Ryder35
21 Jun 2023 09:03
First apply a primer, then spray with a 2K acrylic or polyurethane (PU) paint. Always lightly sand between coats. The surface must be free of dust and grease. Spray paint is the best choice for an even finish.
TARAON
21 Jun 2023 11:47
Hey Sauru, that sounds exciting! 😄
When working with Ikea BESTA fronts, sanding is really the key to success – use fine sandpaper (320 grit or finer), otherwise the paint won’t adhere well.
Regarding the paint: water-based spray paints are great because they have minimal odors and spread nicely. My secret tip: after priming, do a light sanding, then apply the paint in thin coats—better several thin layers than one thick one. This helps prevent runs and uneven spots.
Sometimes a small pressure cleaner for the spray gun nozzle can help keep it from clogging. 😉
Good luck!
meGreg
22 Jun 2023 07:12
This topic is really a science on its own 🎨
Ryder35 schrieb:
First prime, then spray with 2K acrylic or PU paint. Always lightly sand between coats. The surface must be dust-free and grease-free. Spray paint is the best choice for an even finish.
Fully agree!
What I wanted to add: Take your time sanding and then thoroughly clean all residue with a tack cloth or a slightly damp cloth, so no dust remains on the surface.
It also makes sense to bring the cabinet fronts into a well-ventilated room that is not too warm. Otherwise, the paint dries too quickly on top, which causes bubbling.
Another great help is using painting stands, so you can paint both sides of the fronts without setting them down – this prevents damage to the dry paint.
Good luck and feel free to share updates!
nedagla
22 Jun 2023 12:29
Sure, I completely understand that you’re aiming for a perfect result! 😃 You probably don’t want to end up just somewhat satisfied but truly proud of your cabinet fronts!
My advice: It’s not just sanding and painting that matter, but especially the proper preparation of the surface!
- Thoroughly clean the fronts from any dirt using a specialty cleaner for melamine-coated surfaces
- Then use a silicone remover (if you have one or can get it) – this helps the paint adhere better
- Take your time between spray coats to lightly sand the paint (for example, with 400-grit wet sandpaper)
- Patience pays off – many thin layers are much better than a few thick ones!
I’m really excited to hear how it goes for you and keeping my fingers crossed! 🍀
BOMILAN
23 Jun 2023 08:45
Short and practical:
- Thoroughly clean the surface
- Lightly sand (grit 320 to 400)
- Apply a 2K primer or adhesion promoter
- Don’t forget to sand between coats
- Spray paint in thin layers
- Allow each layer to dry well
If you follow these steps, the result will be excellent.
