ᐅ How can I fit Billy shelves perfectly into recessed spaces?
Created on: 27 Mar 2021 14:07
Easongi48
Easongi48
27 Mar 2021 14:07
I am considering installing an IKEA Billy bookshelf in a niche that differs slightly from the standard dimensions. The living room has a niche that is about 5 cm (2 inches) deeper and 3 cm (1 inch) narrower than the standard Billy size. My question is: How can I perfectly adapt the Billy bookshelf to these niche dimensions so that it fits flush and stable without having to do a lot of sanding or makeshift adjustments afterward? Are there proven methods to adjust the niche dimensions to fit the bookshelf, or would it be better to consider custom built-in furniture from the start? I would appreciate any tips on how to best adapt standard Billy shelves to such special room conditions, especially regarding installation and stability.
Thanks in advance for your experiences and suggestions!
Elijah42
27 Mar 2021 15:23
Easongi48 schrieb:
How can I perfectly adjust the Billy shelf to fit these niche dimensions so that it sits flush and stable without having to do a lot of sanding or tweaking afterwards?
I would recommend shortening the back panel slightly or using flexible fillers alongside the shelf instead. Simple sanding of the carcass is difficult; it’s better to make adjustments at the wall or the back panel.
KLONA
28 Mar 2021 09:32
Easongi48 schrieb:
How can I perfectly adjust the Billy shelf to these exact niche dimensions so that it fits flush and stable, without having to do a lot of sanding or modifying afterward?
To adapt a Billy shelf to an uneven niche, I recommend the following approach:
1. Measure: Take very precise measurements of the niche (width, height, depth including any unevenness).
2. Adjust the carcass: Since the Billy shelf has standardized dimensions, modifications are usually necessary on the side panels or the back panel. You can adjust the back panel (Vintage shelves typically have a thickness of only 3 mm (1/8 inch)) or the side panels using a good multifunctional tool.
3. Use filler strips: If there are only a few millimeters of deviation, narrow strips can be used as fillers to make the shelf sit flush and create a level fit.
4. Adjust for slopes: If the floor or ceiling is uneven, it is advisable to balance both sides with filler material or small wedges that can be varied.
5. Fixing: For stability, screws or brackets attached to the niche walls ensure a secure hold.
6. Alternative: If no adjustment is possible, consider combining individual shelf modules (width 40 cm (16 inches)) to fit more compactly within the niche.
Sanding or modifying the carcass is delicate, as it will be visible. Therefore, I recommend using filler strips or wall fixings instead. Hope this helps.
Wesley
29 Mar 2021 11:46
KLONA schrieb:
If the floor or ceiling isn’t completely level, it’s advisable to compensate on both sides using filler material or small wedges that can be adjusted.
Exactly! I would add: take the time to use a spirit level, because even a small mistake there can make the entire shelf look off, and that tends to be more noticeable than a small gap covered by trim. 😊
Also, you can staple or glue small wooden strips to the side edges if the niche measurements are slightly too wide. This way, the Billy shelf will hold firmly without wobbling. Sometimes less is more – especially when you don’t need everything perfectly flush but just a bit of fine-tuning for a better fit.
Oh, and for a neat appearance, you can paint the filler strips or cover them with a foil that matches your wall color – this makes it look much more professional. Good luck with the installation! 🙂
