ᐅ How can I customize IKEA Besta furniture to fit sloped ceilings?
Created on: 15 Nov 2022 18:27
petoneo
Hello everyone, I am facing the challenge of custom-fitting IKEA Besta furniture under a sloped ceiling. My main concern is how to adjust or combine the modules so they fit the angled wall perfectly, without large gaps or compromising stability. Are there any proven methods, special cuts, or clever tricks to optimize Besta cabinets for sloped ceilings? I am especially interested in how to work with IKEA’s standardized dimensions and whether it’s worthwhile to create additional custom wood panels. I look forward to your experiences and tips – including recommendations for tools and assembly techniques that have proven effective.
NOAHSAU schrieb:
IKEA designed Besta precisely for straight walls, and any custom work costs time and money.Thank you for the food for thought; the cost issue is definitely a concern for me as well. However, budget and flexibility are important factors in my case. This limits the options significantly. Therefore, I am looking for ways to make the most of the modular system and achieve a harmonious finish on the sloped ceiling with rather affordable measures. Does anyone have concrete experience with precise custom cuts or clever add-on constructions that don’t require advanced craftsmanship?
The solution is often a "middle ground": using carcasses like those from IKEA Besta and complementing the slope with moldings and panels. I chamfered solid wood panels at the top and sealed them with silicone. An interesting aspect is how you adjust the fronts – sometimes by slightly reducing the height or adding extra trims. It is important to securely fix the cabinets to the wall, as the slope can otherwise cause pressure marks.
I would recommend starting the modules close to the floor and bypassing the slope with concluding wooden filler pieces. This approach helps to avoid issues with the front cladding at the sloped edge. Make sure to measure as accurately as possible and allow some extra space to accommodate any potential inaccuracies.
BOLUKEO schrieb:
Make sure to measure as precisely as possible and plan a little extra space to allow for potential inaccuracies.Exactly, a bit of extra space makes assembly easier and prevents frustration! Also, a dry fit before final fixing helps a lot to ensure everything fits. Don’t let yourself get stressed – with some enjoyment in the process, the result will be great.
A brief final piece of advice: use flexible planning, especially with sloped ceilings where there are many irregular angles. If you divide the furniture into modules and work with different heights, you can visually hide the gaps with some panels or thin trim pieces. A small dry run with unpainted parts before your final assembly can be very helpful in reducing mistakes.
