ᐅ How can I securely build IKEA Platsa furniture on sloped ceilings?
Created on: 1 May 2024 08:42
Nekarste62
I am planning to furnish my attic with IKEA Platsa furniture, but I am facing the challenge of the sloping roof. I am particularly interested in how to properly and securely install the individual Platsa cabinets or modules on the slopes so that they not only fit visually but also stand firmly and can bear weight.
Are there tested methods to firmly and safely fasten the furniture despite the unusual angles? A solution that does not require modifications to the furniture or can be implemented with simple adjustments would be especially important for me.
Does anyone have experience with handling sloping ceilings using the standard dimensions without losing stability? I would appreciate tips, recommendations on fasteners, and, if possible, any reports on how you adapted Platsa furniture to inclined walls.
Thank you very much in advance for your help!
blapau
2 May 2024 09:30
Maria35 schrieb:
Special brackets with angled cuts or adjustable furniture brackets can compensate for the slope and provide better support.
I can confirm this. Without these brackets, there are often point loads on the back panel, which can lead to deformation over time. Universal furniture brackets with adjustable angles are very helpful here and can be found at hardware stores.
Nekarste62
3 May 2024 07:45
Thanks to everyone for the helpful contributions!
For my project, I will try the following:
- Precise angle measurement, 38°
- Adjusting the back sides with wooden panels to create a stable support
- Installing metal brackets with the necessary bevel cuts
- Making a base frame to prevent tipping movements
- Using different types of anchors depending on the wall material
The tip about adding an extra wooden panel on the back especially opened my eyes. If any of you have experience with the ideal wood thickness or fastening methods, please let me know.
I will report back on how it went!
CHENFAR
3 May 2024 08:10
Nekarste62 schrieb:
If any of you have experience with the ideal wood thickness or fastening methods, feel free to share.
It is recommended to use multiplex or plywood panels at least 18mm (0.7 inches) thick, as they provide good stability while maintaining a manageable thickness. These panels are best fastened with wood screws combined with adhesive to ensure a permanently strong connection. When mounting to a wall, appropriate spacers should be used to prevent stress or deformation.
