Hello everyone, I am currently planning to visually and functionally separate the area between the living room and dining space in my fairly open apartment without installing a solid wall. My idea was to use the Ikea PAX wardrobe systems as room dividers because they are flexible and also provide storage.
Does anyone have experience or good tips on how to best arrange the PAX units as room dividers? What dimensions make sense, how to stabilize them if the compartments remain open, and do you have examples of how to make the whole setup visually appealing?
I’m especially looking for practical advice regarding installation, weight, and the overall effect in the room. Thanks in advance for your suggestions!
hauklo schrieb:
Before installation, you should check the floor level because PAX requires precise alignment for stable support.This is often an underestimated point. I also had problems with my setup because the floor wasn’t completely level, and the modules shifted slightly even though everything was screwed together. I then used small shims that can still be adjusted later, keeping everything stable and level.
Additionally, if you’re using PAX as a room divider, I recommend choosing doors that can be easily operated from both sides. Try opening them as a test when the wardrobe is placed in the middle of the room – some hinges might be impractical if you only have access from one side.
Another tip: lighting, such as LED strips inside the open compartments, creates a nice atmosphere and highlights the room divider within the room. This works well if you integrate open compartments with visibility from both sides.
Good luck with your project!
