Hello everyone, I am planning to repaint an Ikea Hemnes wardrobe as part of a DIY project to enhance its appearance and better match my living concept. I am looking for a method that is as sustainable and durable as possible, and suitable for skilled home DIY enthusiasts. I understand that the Hemnes is usually made of solid pine and coated with a clear lacquer or a veneer finish, which makes the surface quite smooth. My question is: What is the best and most long-lasting way to repaint the wardrobe without the paint peeling or coming off over time? What preparation, sanding technique, primer, and types of paint are recommended? I am especially interested in experiences with chalk paint, acrylic or enamel paints, sealing, and potential pitfalls. Thank you very much in advance for your tips and advice!
FEKAU schrieb:
First, thoroughly clean the furniture parts to remove all grease and dirt residues.I agree and would add that before any further treatment, the surface must be completely dust-free. I also recommend strictly observing the drying times in addition to applying the primer to ensure optimal adhesion. If the times are too short, the paint layer may peel off.
To conclude, I can offer the following tips: - After the final sanding, be sure to remove all sanding dust residues, preferably with a damp cloth, and then allow the surface to dry. - For the primer and paint, it is best to choose branded products, as cheaper paints often become too brittle and are not durable. - If you want a special look, you can lightly sand with fine-grit sandpaper after painting and try a patina technique. - Whether using a spray gun or a brush, it is always important to apply thin layers and allow sufficient drying time. With any furniture painting, patience is a key factor for a perfect, long-lasting result.
