ᐅ How can I repaint Ikea Hemnes furniture as a DIY project?
Created on: 17 Sep 2021 08:34
PIKEO8
PIKEO8
17 Sep 2021 08:34
Hello everyone, I am planning to repaint an Ikea Hemnes wardrobe as part of a DIY project to enhance its appearance and better match my living concept. I am looking for a method that is as sustainable and durable as possible, and suitable for skilled home DIY enthusiasts. I understand that the Hemnes is usually made of solid pine and coated with a clear lacquer or a veneer finish, which makes the surface quite smooth. My question is: What is the best and most long-lasting way to repaint the wardrobe without the paint peeling or coming off over time? What preparation, sanding technique, primer, and types of paint are recommended? I am especially interested in experiences with chalk paint, acrylic or enamel paints, sealing, and potential pitfalls. Thank you very much in advance for your tips and advice!
FEKAU
17 Sep 2021 09:02
Hello, I generally recommend the following procedure for painting the Ikea Hemnes wardrobe: - First, thoroughly clean all furniture parts to remove any grease and dirt residues. - Then, lightly sand the surface with fine sandpaper (grit 180-220) to roughen the existing paint layer, which improves adhesion. - After that, apply a high-quality wood primer, specifically one designed for previously painted surfaces. This creates a uniform base and bonding layer for the subsequent paint. - For the paint, I recommend water-based acrylic or acrylic lacquer. These have low odor, are relatively environmentally friendly, and provide a durable finish. - Finally, it is advisable to seal the wardrobe with a clear coat to protect it from scratches and moisture. It is important to allow each coat to dry thoroughly and, if possible, work in a dust-free environment. Proper preparation is crucial to prevent peeling and chipping.
Laukau5
17 Sep 2021 10:15
Regarding preparation and technique, I would like to go into more detail, as this is often where mistakes occur: Before sanding, it is advisable to remove all hardware and degrease the surface, for example with alcohol or a specialized degreaser. Afterward, I recommend working the surface with a sanding sponge or sandpaper in several stages—starting with grit 120, then 180, and finishing with 220. This roughens the paint slightly without damaging it enough to expose the wood grain. This is especially important for Hemnes furniture, as its surface finish consists of a clear coat or foil layer that is very durable. The primer should provide good adhesion; a polyurethane-based bonding primer works well here. About 2 to 3 thin coats with sanding between each layer are ideal. For the paint itself, I recommend acrylic paints due to their flexibility, which helps absorb stresses and prevent cracking. Additionally, with a high-quality paint, you can achieve a glossy, satin, or matte finish depending on your preference. For application, I suggest spray guns to achieve an even surface and avoid runs—but brushes and rollers are also an option if used carefully. A well-ventilated room, consistent temperature (ideally 20 degrees Celsius [68°F]), and a dust-free environment are essential for a perfect outcome.
PIKEO8
17 Sep 2021 11:08
Laukau5 schrieb:
For the paint itself, I recommend acrylic paints because of their elasticity, which absorbs stresses and prevents cracking.
Thank you for the detailed information. I have a question to better understand: Does the acrylic paint layer need to be applied thinly to maintain elasticity? Wouldn't a thicker layer be more durable? Also, do you have any experience with chalk paint in this context? Some claim that chalk paint does not require a primer and is still durable.
kibutar
17 Sep 2021 14:37
Regarding layer thickness and chalk paint, I can share some experience: A paint layer that is too thick tends to develop stresses during drying, which can lead to cracking. Therefore, it is better to apply several thin layers rather than one thick layer. Each layer should be applied evenly and fully cured before applying the next.
Concerning chalk paint: This type of paint has the advantage of adhering well to many surfaces and producing a matte, velvety finish. However, it is generally less resistant to mechanical wear and moisture. For this reason, despite many different recipes, sealing with wax or a special clear coat is usually recommended.
Primers are often not strictly necessary with chalk paint, but for glossy surfaces such as a lacquered Hemnes, I recommend light sanding without heavy removal or using an adhesion primer to improve durability. Otherwise, the paint may peel off later.
Proper surface preparation is important, even though chalk paint is considered easy to use.
glapu
18 Sep 2021 07:21
I can add: Spraying is the best method for applying the paint. Sanding after each coat improves adhesion. When sealing, pay attention to the clear coat – a matte clear coat performs best for cabinets that are used frequently.
