ᐅ Heat loss in hot water supply between the heating system and the bathroom: 40%
Created on: 13 Aug 2017 18:11
O
Ostfriese
O
Ostfriese
13 Aug 2017 18:11
I noticed that out of 65°C (149°F) in the water heater, only 40°C (104°F) reaches the bathtub, so about 40% is lost over a distance of 10 meters (33 feet). I would like to reduce the heat loss in the hot water pipe between the heating system and the bathroom to nearly zero. The pipe is insulated with both foam and glass wool around the foam. Is there an insulation for hot water pipes that greatly limits heat loss? I would like to keep the temperature setting as is due to bacteria concerns and then cool down to the desired temperature with cold water when taking a bath.
Caspar2020
13 Aug 2017 18:48
Measured at the hot water connection directly or after a mixing valve?
I assume the latter, either with a maximum limit or that water is always being mixed.
Caspar2020
13 Aug 2017 18:50
Or just for fun, turn off the cold water in the bathroom and see if the temperature stays the same.
O
Ostfriese
13 Aug 2017 21:45
thank you for the responses. No cold water is added to the hot water.
