ᐅ High electricity consumption of the heat pump
Created on: 24 May 2016 08:02
Schwupp
Schwupp
24 May 2016 08:02
I completed building my house last May.
So far, everything is fine. However, I am a bit concerned about the electricity consumption of my air-to-water heat pump. My installer told me that the consumption for the first year is normal since the masonry is still damp. But somehow, I don’t quite believe that. Therefore, I wanted to ask you if you still find the consumption normal.
About the house:
Living area 170 sqm (1830 sq ft) + 80 sqm (860 sq ft) basement. Fully equipped with underfloor heating. However, the basement is not heated.
Central ventilation system with heat recovery from Vallox.
KfW 70 standard.
Calculated energy demand: 50.7 kWh/sqm (16,230 kWh/1,000 sq ft).
Heating system:
Mitsubishi Zubadan 11.2 kW without electric heating element.
Multifunction water storage tank from Zeeh, 840 liters (222 gallons).
Settings:
Domestic hot water: 50°C (122°F)
Flow temperature: 23.9°C (75°F)
Return circulation temperature: 38°C (100°F)
Normal room temperature: 21°C (70°F)
Night setback: 18°C (64°F)
Heating curve:
Slope: 0.30
Max flow temperature: 45°C (113°F)
Min flow temperature: 15°C (59°F)
Control: outdoor temperature
Room temperature regulation individually. Average temperature 21°C (70°F). About 22.5°C (72.5°F) in the bathroom.
Electricity consumption of the air-to-water heat pump (separate meter)
July: 122 kWh
August: 128 kWh
September: 347 kWh
October: 808 kWh
November: 1000 kWh
December: 1019 kWh
January: 1530 kWh
February: 1274 kWh
March: 1246 kWh
April: 738 kWh
This results in an annual consumption of about 9000 kWh. That seems quite high to me.
Thanks in advance for your responses.
Regards,
Andre
Legurit
24 May 2016 09:43
9000 kWh (not kW/h) output or actual electricity consumption?
The setup seems unfavorable... without knowing the system. 11.2 kW is quite a lot; what is the 800-liter (211-gallon) storage tank used for? I assume it needs to be kept warm constantly.
Try lowering the hot water temperature to 46°C (115°F) and turn off the heating element.
Visit the pink forum and describe your situation.
That would be over €150 per month if that is really electricity consumption...
Legurit
24 May 2016 11:04
Please go to the pink forum… you are wasting money (ironically, considering you are heating with a heat pump).
Schwupp
24 May 2016 11:06
Thank you.
I have now posted the question in the pink forum.
