ᐅ Heat Protection for Recessed Lighting
Created on: 9 Dec 2019 18:02
Christel82
Christel82
9 Dec 2019 18:02
Hello, I need some help. We installed recessed lights in our drywall ceiling. To protect against heat damage, we mounted spacers behind the lamps. Now my problem is this: directly behind one hole there is a thick wooden beam measuring about 50cm by 50cm (20 inches by 20 inches). Unfortunately, we had to cut a hole into the beam; otherwise, the lamp wouldn’t fit. There is no space for a spacer. Can I line the cut-out hole with something to provide heat protection? If so, with what? Heat-resistant paint used for stoves? Titanium heat-resistant tape or just simple aluminum tape? Maybe someone has some advice.
danixf
9 Dec 2019 18:41
Recessed housing ThermoX® LED
seat889 Dec 2019 18:41
Why not use LEDs? They hardly get warm or don’t heat up at all. No clearance is needed.
Christel82
9 Dec 2019 18:43
danixf schrieb:
Google
Unfortunately, this does not fit into the routed hole; I would need to rout more of the beam, which I prefer not to do.
Christel82
9 Dec 2019 18:44
seat88 schrieb:
Why don’t you use LEDs? They hardly get warm or don’t get warm at all. No clearance is needed.
I have LEDs, but they still get quite warm.
seat889 Dec 2019 19:24
Christel82 schrieb:
I have LED lights, but they still get quite warm.
Aha
