ᐅ Guest Toilet – Ceiling or Wall Outlet?
Created on: 14 Jun 2019 22:42
Andre77
Andre77
14 Jun 2019 22:42
the title says it all. Is there any reason to choose one over the other?
Thank you for your feedback!
guckuck2
14 Jun 2019 22:46
Andre77 schrieb:
The title says it all.
Toilets should ideally drain downward, meaning a floor outlet.
Or did you want to ask something else?
If so, you’ll need to provide a bit more detail.
Andre77
14 Jun 2019 22:51
Oops... um, yes. I naturally meant the outlet for the lighting.
Bookstar
14 Jun 2019 23:05
Why do you want to illuminate the toilet?
14 Jun 2019 23:09
guckuck2 schrieb:
Toilets should ideally drain downward. So, a floor outlet.
I thought the same 😉
For a small guest bathroom, a wall outlet is sufficient. Having both would be too much, and a ceiling outlet is not good for the mirror.
11ant15 Jun 2019 01:16
Andre77 schrieb:
Of course, I meant the outlet for the lighting.
Well, I must have mistyped there: my thought was about the ventilation (one of the many detailed issues in the Hotzenplotz construction).
