Andre77 schrieb:
The title says it all. Toilets should ideally drain downward, meaning a floor outlet.
Or did you want to ask something else?
If so, you’ll need to provide a bit more detail.
guckuck2 schrieb:
Toilets should ideally drain downward. So, a floor outlet.I thought the same 😉
For a small guest bathroom, a wall outlet is sufficient. Having both would be too much, and a ceiling outlet is not good for the mirror.
Andre77 schrieb:
Of course, I meant the outlet for the lighting.Well, I must have mistyped there: my thought was about the ventilation (one of the many detailed issues in the Hotzenplotz construction).https://www.instagram.com/11antgmxde/
