ᐅ Flickering with Paulmann URail Spot Circle?
Created on: 16 Mar 2020 19:25
bububu11
does anyone know if the Paulmann Spot Circle (URail) flickers a lot? Unfortunately, the Paulmann hotline cannot provide any information on this.
I am uncertain because I have a Paulmann LED that flickers quite noticeably. The flickering is visible to the naked eye. In many photos, you can see a distinct black band caused by the flickering (visible with my RX 100 M4).
danixf
16 Mar 2020 22:17
rick2018 schrieb:
Try connecting the Paulmann, for example, to an uninterruptible power supply (UPS) to ensure a stable voltage. If they still flicker, the issue is with Paulmann. If not, it’s your electrical system.
Well, not everyone necessarily has a UPS at home.
In any case, as Rick already said, try to narrow down the problem. Is the flickering happening everywhere? Maybe test it at a friend’s place. Does it flicker all the time or only at certain times?
rick201816 Mar 2020 22:20
For example, I wrote that there are other options for a power supply with a smoothed signal.
bububu11
17 Mar 2020 08:41
Isn't it a design flaw if the LED flickers even at its brightest setting? You would expect the PWM to be off in the brightest mode.
