ᐅ Important Factors to Consider When Choosing Tiles
Created on: 23 Feb 2014 15:01
f-pNo
f-pNo23 Feb 2014 15:01
On Tuesday, we will be reviewing our tile samples.
Are there any specific characteristics we should keep in mind?
What I mean is: with laminate flooring, for example, there is an abrasion class to consider. A low abrasion class means that with heavy use, the laminate will wear out more quickly.
Is there something similar to watch out for with tiles?
I could imagine that factors like heat transfer and heat retention depend on the tile thickness or material.
Perhaps there are also certain features related to tile floor cleaning that we should consider (for example, tiles made from material XY might be easier to clean than tiles made from material Z).
This is the kind of question I have in mind.
So, go ahead—what should we pay attention to?
23 Feb 2014 18:56
Abrasion classes also apply to tiles. For example, bathroom tiles are not suitable for entrance areas.
Thermal conductivity can be disregarded since tile material is generally the best for underfloor heating.
Matte or rough surfaces are the most natural-looking, but if you wear socks, you are more likely to get holes.
Polished surfaces are, in my opinion, the most demanding to maintain. Solid-colored tiles are the same.
amelie74
23 Feb 2014 21:30
We are facing this as well. Friends advised us to definitely test the sample tile at home to see if stains remain. For example, they spilled red wine and coffee and let it sit overnight. Only after this test did they make the final purchase.
In other forums, polished porcelain tiles were discouraged because they didn’t get properly clean during cleaning. There were reports of permanent smudge films.
As I said, these are not my personal experiences. Maybe someone here in the forum can share some insight.
Jaydee24 Feb 2014 10:41
Our tile installer was impressed with our tiles because they were through-body porcelain. That’s probably another tip I can give you. If any chips appear, it wouldn’t be too noticeable since the color continues through beneath the surface layer.
Additionally, when selecting our tiles, we made sure they weren’t too smooth. This way, dust particles or hairs don’t show up as easily.
24 Feb 2014 12:46
Yes, full-body coloration is beneficial in case the tile gets damaged; the damage won’t be immediately noticeable.
Additionally, it is important (especially if the budget is limited) not to choose tiles that are too large. For large formats, usually from 30 x 60 cm (12 x 24 inches) and above, the installation effort is higher, which often results in increased labor costs. Large format tiles also tend to warp slightly, so they may not lie completely flat...
f-pNo28 Feb 2014 13:16
So – thank you very much for the suggestions. The selection of materials has been successfully completed.
As expected, the costs have increased – only the tiles for the utility room and storage room have become cheaper.
The tiles for the hallway / corridor / kitchen might be a “silent budget killer.” When I mentioned this, the consultant denied it – we’ll see. On the other hand, we have always worn house slippers and rarely walked around in just socks. Only my daughter still needs to get used to that.
All tiles will be color-through.
Living room: wood-look tiles
Kitchen / hallway / corridor: porcelain stoneware tiles (with a Mediterranean style) with a pattern that doesn’t show dirt immediately
Bathroom: walls in cream color and flooring rather dark
I know – not a great description, but I don’t have more detailed information at the moment and am still waiting to receive the complete offer (with names, etc.).
