ᐅ Extremely Loud Bangs from the Flat Roof
Created on: 13 Jan 2022 10:04
Flinstone
In 2015, we built a prefab house from Schwabenhaus with a flat roof. Whenever there is frost and the temperature drops below 0 degrees Celsius (32°F), extremely loud cracking noises can be heard from the roof inside the house. These sounds are comparable to a gunshot—so loud that they wake you up at night. The noise can even be heard by neighbors.
We have not received any response from the builder regarding this roof issue.
Maybe someone here has experienced the same problem with their roof and, ideally, has found a solution. I would appreciate any helpful advice!
Thank you very much in advance and best regards,
Flinstone
13 Jan 2022 20:43
driver55 schrieb:
that's just how it is
.. I did not write that. I explained it. Briefly but clearly.
And you? You are pointing to other topics…
driver55
14 Jan 2022 08:17
Was this issue present from the beginning, or did it develop over time?
Have you identified any other homeowners (with the same construction company) experiencing the same problem?
