ᐅ Evaluation of the Quote (5 Windows and a Balcony Door Including Removal and Installation)
Created on: 19 Dec 2020 12:57
MoeTavern
I have received a quote for the installation of new windows (including removal and disposal of the old windows). Since this is my first time doing this, I would appreciate your input on whether this is a reasonable price (location Ruhr area).
Offer price: €5,100 gross
Included according to the quote:
Veka Softline 76 AD
2 windows: single-leaf tilt-and-turn windows measuring 1210 x 1460 mm (48 x 57 inches), double-glazed thermal insulation glass with a Ug value of 1.1, white (€347 net each)
1 window: single-leaf tilt-and-turn window measuring 1215 x 1450 mm (48 x 57 inches), double-glazed thermal insulation glass with a Ug value of 1.1, frosted glass, white (€391 net)
1 window: double-leaf tilt-and-turn/turn window with fixed mullion measuring 1820 x 1460 mm (72 x 57 inches), double-glazed thermal insulation glass with a Ug value of 1.1, white (€602 net)
1 window: double-leaf tilt-and-turn/turn window with fixed mullion measuring 1720 x 1460 mm (68 x 57 inches), double-glazed thermal insulation glass with a Ug value of 1.1, white (€582 net)
1 balcony door: single-leaf tilt-and-turn door measuring 790 x 1970 mm (31 x 78 inches), double-glazed thermal insulation glass with a Ug value of 1.1, white (€343 net)
Removal, disposal, and installation of 6 windows including foam insulation, interior finishing, exterior sealing; painting work to be done separately by a painter (€1,710 net)
Thanks in advance!
Veka Softline 76 AD
Thanks in advance!
MoeTavern schrieb:
I’m really not familiar with this. I have seen MD used in online configurations. The windows are generally significantly cheaper there. [...] The installation costs seem extremely high to me. There may be some profiles designed cleverly enough to perform well with rebate seals. However, in my opinion, it is generally advisable to go with a central seal (MD), since "AD" practically means "without MD." Purchasing windows with installation included is a smart choice—but unfortunately, good installation requires professionals and is therefore quite costly. Window installation is unfortunately a trade without any mandatory certification, meaning that the formal permission to work does not guarantee competence. As a result, there are more fearless amateurs working in this field than our conventional wisdom would imagine. My main reason for withdrawing from the window industry was the shortage of skilled installers in the market.
Joedreck schrieb:
I’m just wondering why only double glazing is being used? That’s a 1995 standard. For renovation, triple glazing is not necessarily better.
In general, that’s just another cliché repeated without real substance.
tomtom79 schrieb:
Well, a U-value of 1.1 is not just an offhand remark.But we actually don’t know the U-value of the exterior walls. So this should be taken just as a saying... everything has to fit together in a house! And if Joe had built it in 1995, he certainly wouldn’t have had triple glazing as standard in his new build.
