ᐅ Eternit as an alternative roofing material to clay roof tiles?
Created on: 27 Apr 2020 10:38
annab377
annab377
27 Apr 2020 10:38
Our architect actually recommended clay roof tiles, but an acquaintance suggested that we should also consider fiber cement roof tiles (Eternit), as they are significantly more affordable than clay tiles.
Concrete roof tiles are less of an option for us due to some negative reports about them deteriorating after a few decades.
Has anyone had experience with the company Eternit? Asbestos hasn’t been used for several years now, so what are the pros and cons of fiber cement panels as roof covering?
Thank you very much for all suggestions and experiences.
nordanney
27 Apr 2020 10:54
annab377 schrieb:
Our architect actually recommended clay roof tiles, but an acquaintance suggested that we should also consider fiber cement roof tiles, since they are supposedly much cheaper than clay tiles.
I think that is a myth.
annab377 schrieb:
Concrete roof tiles are excluded because of rather negative claims that they deteriorate after a few decades, etc.
“Rather negative claims”? Another myth.
It’s all a matter of taste and budget. Nothing more, nothing less.
annab377
27 Apr 2020 11:12
Yes, in terms of appearance, I think clay and concrete roof tiles are now very similar. Both are available in all shapes.
It's a tough decision. Of course, I don’t want to spend unnecessary money if there is a more affordable but equally durable option. What kind of roofing do you have, @nordanney?
nordanney
27 Apr 2020 11:21
annab377 schrieb:
What do you have on your roof, @nordanney?
For our private homes, we used concrete roof tiles in the last two houses. The rental properties I manage also have them. A lifespan of 50 years is sufficient—usually, the builders decay long before that...
Lumpi_LE
27 Apr 2020 11:41
Clay roof tiles are not as dimensionally precise as concrete tiles, so the appearance of a roof is simply different. Durability is no longer a concern for either option.
annab377
27 Apr 2020 12:50
Thank you for your responses.
Does it matter if you want to install a full-surface photovoltaic system whether you choose clay roof tiles or concrete roof tiles? Probably not, right? The roof hook solution will be the same for both types.
