freisinger14 Feb 2020 12:52Hello everyone,
Currently, my heating contractor is offering a Novelan brine-to-water heat pump. To qualify for the 10,000 Houses Program (Bavaria), the storage tank must meet the following requirements:
- Thermal storage with at least 30 liters per kWthermal effective volume
- Storage insulation with heat retention loss S < 8.5 + 4.25·V^0.4 or U-value ≤ 0.20 W/m²K
- The main criterion for the storage tank’s eligibility for funding is its heat retention loss. Under the 10,000 Houses Program, storage tanks with an energy efficiency class A or better are supported.
Question for you: Are there storage tanks with the above specifications that can be combined with a Novelan SIC 12.3 and have an approximate volume of 400 liters (105 gallons)?
My heating contractor can’t find any.
Thanks in advance.
Thanks in advance.
There are quite a few options.
You can check with the manufacturer OEG or Thermic Energy.
We sourced our 200L (53 gallons) storage tank from them for the 10,000 Houses Program back then.
I quickly found two for you (with energy efficiency ratings A or A+):
Alternatively, there is a good overview available from C.A.R.M.E.N. EV:
Search online for "Marktübersicht Wärmespeicher Carmen-ev" and open the PDF there.
However, all of these tend to be relatively expensive.
freisinger16 Feb 2020 16:44truce schrieb:
There are several options.
Check the manufacturers OEG or Thermic Energy.
Search for "Market Overview Thermal Storage Carmen-ev" and open the PDF there.
However, all of these are relatively expensive. Thank you very much. I will start researching right away.
