ᐅ Electrical connection for underfloor heating
Created on: 15 Sep 2017 18:37
Paulus16
in the electrician’s quote for our new single-family house (2 floors, approximately 185 m² (1,991 sq ft)), I noticed an item called "connection for underfloor heating" costing 750€. The thermostats are listed separately in another item. This amount seems quite high to me. Does anyone know what this item typically includes?
Paulus16
15 Sep 2017 20:58
Joedreck schrieb:
Does the wiring and connection also include the thermostats?
It says: Gira room thermostat uP: 59€
Joedreck
16 Sep 2017 07:35
That sounds like it’s just about the thermostat itself. Could the position actually refer to the connection and installation?
It’s best to just ask him. If he’s reliable, he will break it down for you individually and explain it in detail.
Caspar2020
16 Sep 2017 07:43
That is just the thermostat then.
dohuli
16 Sep 2017 08:14
From each room thermostat, a cable must be run to the respective heating circuit manifold (I assume you have two). Additionally, each heating circuit manifold requires a supply line, and last but not least, the room thermostats need to be connected to the actuators on the manifold.
This involves a considerable amount of work and adds up to quite a few meters of cabling. I can say this from experience, as I recently did this myself in my new build (172 m² (1847 sq ft)) a few weeks ago.
750 € is not a bargain, but it is certainly not too expensive.
The 59 € is—as mentioned several times—only the material cost for the room thermostat.
Paulus16
19 Sep 2017 13:04
So the electrician explained it to me today. It is exactly as dohuli described.
