ᐅ Semi-detached house 7x12 m with additional rooms on the ground floor
Created on: 4 Sep 2018 10:00
sireg
we have been offered a plot of land measuring 10x60m (33x197 ft) for a semi-detached house. The other half will be built by friends of ours who have similar requirements.
Now we are considering how this could fit our needs.
  • The house dimensions are specified as 7x12m (23x39 ft) or 6x10m (20x33 ft), with two full stories and a gable roof. The plot is flat, and the terrace faces south-southeast.
  • There are five of us, and we need three children’s bedrooms, one master bedroom, an open plan kitchen-living area (preferably with a kitchenette tucked into a niche), a bathroom, a separate toilet with a shower, a utility room (with solar storage and heating system), and a cloakroom.
  • The three children’s rooms and the bathroom should be located on the upper floor.
We are now looking for a floor plan that includes space for a bedroom on the ground floor—12sqm (130 sq ft) should be sufficient. If possible, I would then place the utility room under the roof. The rest of the attic space would be used for storage.
So far, I haven’t been able to find any floor plans online that include an additional room on the ground floor.
Do you have any pictures or links for me?
At some point, the children will likely move out, and we will need less space. It would be nice if it were possible to separate a self-contained apartment. This should probably be considered now so that the later effort is not too great...
I look forward to many ideas and pictures.
Simon
sireg
4 Sep 2018 12:33
At the moment, it is almost impossible to find a large, decent apartment in a good location. And if one does become available, the rental prices are so high that buying property might be a better option.
In addition, we want to have a large garden directly adjacent to the house – currently, we have a leased garden further away.
I can’t say for sure yet whether I will want to rent out an apartment (or holiday flat) later on. It’s quite possible that once we are settled, we will want to keep the space. But by considering it now, I will keep all options open for the future.
haydee
4 Sep 2018 12:42
You are building now based on your current needs. If the house turns out to be too big later, you can do what Nordlys did and build a bungalow to suit the needs you then have. That way, there are only compromises.
Then accommodate the older children upstairs. If you’re healthy, there is nothing against having a staircase. At least, nothing that outweighs the disadvantages of a small bedroom footprint.
sireg
4 Sep 2018 14:18
Thank you for the suggestions. A very small bedroom doesn’t bother us. It’s just for sleeping, after all...
Maybe someone else can help with the floor plans.
11ant4 Sep 2018 16:00
For a semi-detached house designed for towels, I consider options like a granny flat or holiday apartment to be impractical.
sireg schrieb:
We were offered a plot of land (10m x 60m) (33ft x 197ft) for a semi-detached house. The other half would be built by friends of ours who have the same requirements.
Now we are considering how this might fit our needs.
My most obvious thought would be to split the entire plot into two 20m x 30m (66ft x 98ft) sections instead. Even with an easement for the rear neighbor / right of way, this would create much more conveniently buildable plots with greater flexibility. Alternatively, you could build a duplex together. But stacking all your family on a bowling alley doesn’t make much sense.
kaho6744 Sep 2018 16:06
What does the zoning plan specify?
A pointless discussion without all the information from the questionnaire...
MadameP4 Sep 2018 21:34
My first thought would be to divide the entire plot into two sections of 20 x 30 meters (66 x 98 feet) each.
10 x 60 divided by 2 gives 10 x 30... it’s not going to get any wider anyway
