ᐅ DK Summer House Insulation & Wall Construction
Created on: 26 May 2026 16:52
JulianWue
I hope you can help me with my renovation project.
I am currently renovating a small summer house from the 1970s in Denmark (approximately 40 m² (430 sq ft) of living space). Typical Danish summer houses often have relatively thin timber stud walls; in my case, they are currently 7 cm (2.75 inches).
The original wall structure was:
  • Wooden cladding nailed directly onto the studs (without ventilation)
  • A wind barrier made of a type of tar paper underneath
  • 7 cm (2.75 inches) of mineral wool insulation between the studs
  • Gypsum board on the inside
The walls are now completely stripped down, and the old insulation has been removed. Unfortunately, the walls were heavily infested with mice, which likely got in from the floor area. Addressing the floor sealing and closing holes to prevent mice ingress is therefore also on my to-do list.
The planned new wall build-up from outside to inside is:
  1. New ventilated wooden cladding
  2. Breathable wind barrier / membrane
  3. Timber studs with 7 cm (2.75 inches) of mineral wool insulation
  4. 12 mm (0.5 inch) OSB airtight glued
  5. Installation cavity inside of about 4-5 cm (1.5-2 inches)
  6. Wood paneling as interior finish
Since the house is only used occasionally and not permanently heated, I expect stronger temperature and humidity fluctuations. At the same time, we want to use the house both in summer and winter.
My main question:
  • Would you insulate the installation cavity additionally or leave it intentionally empty?
The additional 4-5 cm (1.5-2 inches) of insulation would of course be interesting from an energy perspective, especially since the main insulation of 7 cm (2.75 inches) is rather limited. On the other hand, I often read that additional interior insulation can be problematic because the OSB layer could get too cold, potentially causing condensation issues—especially in buildings that are not heated continuously.
I am also concerned about the following:
  • Do I need to pay attention to specific values or parameters with the breathable wind barrier?
  • Has anyone had experience with products like “Nordland Vindspærre diffusionsåben”?
  • What do you think about using 4 cm (1.5 inches) Gutex wood fiber boards on the outside instead of a classic breathable wind barrier? Does that make sense in my setup, or is it unnecessarily expensive?
Thank you very much!
Julian
JulianWue
26 May 2026 22:18
Hello MachsSelbst,
thank you very much for your feedback!
The house is intended to be usable during winter, but it will not be continuously heated (which is not uncommon here in Denmark).
The condition of the wood was/is good; only the insulation has suffered from mice. However, it should also be mentioned that the previous owners did not use the house in winter or were unable to (too cold, according to their statement).
julian
JulianWue
26 May 2026 22:21
Based on the previous feedback, I am leaning towards the following setup:
  1. New ventilated timber facade
  3. Timber studs with 7 cm (3 inches) mineral wool insulation
  4. 12 mm (0.5 inch) OSB airtight sealed
  5. Interior installation cavity of about 4–5 cm (1.5–2 inches) (without insulation)
  6. Wooden panels as interior finish
MachsSelbst
27 May 2026 09:06
JulianWue schrieb:
The house should also be usable in winter
It is, as long as you install a proper heating system. I have stayed professionally several times during winter at a campsite in Sweden in lightweight bungalows, with temperatures down to -15°C (5°F) at night, heated only by electric heaters. It works and is definitely much more cost-effective than investing heavily in insulation and other measures for just 2–3 weeks a year.
Germans tend to always go for the deluxe solution, while Scandinavians are much more pragmatic. 😉
Grundaus
27 May 2026 10:19
I have a wooden extension with wood fiberboard on the outside beneath the cladding. I consider this better than using any kind of membrane, as it provides additional insulation and is more forgiving of errors.
