ᐅ DK Summer House Insulation & Wall Construction
Created on: 26 May 2026 16:52
JulianWue
JulianWue
26 May 2026 16:52
I hope you can help me with my renovation project.
I am currently renovating a small summer house from the 1970s in Denmark (approximately 40 m² (430 sq ft) of living space). Typical Danish summer houses often have relatively thin timber stud walls; in my case, they are currently 7 cm (2.75 inches).
The original wall structure was:
  • Wooden cladding nailed directly onto the studs (without ventilation)
  • A wind barrier made of a type of tar paper underneath
  • 7 cm (2.75 inches) of mineral wool insulation between the studs
  • Gypsum board on the inside
The walls are now completely stripped down, and the old insulation has been removed. Unfortunately, the walls were heavily infested with mice, which likely got in from the floor area. Addressing the floor sealing and closing holes to prevent mice ingress is therefore also on my to-do list.
The planned new wall build-up from outside to inside is:
  1. New ventilated wooden cladding
  2. Breathable wind barrier / membrane
  3. Timber studs with 7 cm (2.75 inches) of mineral wool insulation
  4. 12 mm (0.5 inch) OSB airtight glued
  5. Installation cavity inside of about 4-5 cm (1.5-2 inches)
  6. Wood paneling as interior finish
Since the house is only used occasionally and not permanently heated, I expect stronger temperature and humidity fluctuations. At the same time, we want to use the house both in summer and winter.
My main question:
  • Would you insulate the installation cavity additionally or leave it intentionally empty?
The additional 4-5 cm (1.5-2 inches) of insulation would of course be interesting from an energy perspective, especially since the main insulation of 7 cm (2.75 inches) is rather limited. On the other hand, I often read that additional interior insulation can be problematic because the OSB layer could get too cold, potentially causing condensation issues—especially in buildings that are not heated continuously.
I am also concerned about the following:
  • Do I need to pay attention to specific values or parameters with the breathable wind barrier?
  • Has anyone had experience with products like “Nordland Vindspærre diffusionsåben”?
  • What do you think about using 4 cm (1.5 inches) Gutex wood fiber boards on the outside instead of a classic breathable wind barrier? Does that make sense in my setup, or is it unnecessarily expensive?
Thank you very much!
Julian
Nichtganz
26 May 2026 17:19
Good evening,
I would recommend leaving the installation level mostly empty or only lightly insulated. For a summer house with occasional use like this, a robust structure that dries out properly is usually more important than adding the last few centimeters of insulation.
The OSB board already serves as a decent vapor retarder in your assembly. If you add another 5cm (2 inches) of insulation inside, the board can quickly become too cold, especially in winter when heating is occasional. This often only becomes noticeable years later.
TecLoc
26 May 2026 18:07
The issue with the installation layer is actually straightforward and doesn’t leave much room for debate. Once you add another 4–5cm (1.5–2 inches) of insulation on the inside, you shift the temperature gradient closer to the OSB board. With your assembly having only 7cm (2.75 inches) of cavity insulation, this doesn’t really improve anything; it just increases the risk that the OSB will remain cold for longer during winter. This exact combination of low thermal mass, variable use, and moisture is the critical factor—not the U-value in the Excel sheet.
The idea of “quickly adding some wood fiber insulation on the outside instead of a wind barrier” suggests that building physics is being mixed up with material shopping. A wood fiber board does not replace a proper windproofing layer. If there isn’t a clearly defined, vapor-open yet windproof layer on the outside, the best insulation won’t help because air will flow through the structure. And no, “vapor-open” does not automatically mean suitable.
More relevant is the connection at the base to prevent mice. This is regularly overlooked in summer homes until you hear rustling again. Open joints at the base or unsealed penetrations will compromise any wall assembly, no matter how well the rest is planned.
JulianWue
26 May 2026 20:42
Thank you for your feedback, "nichtganz" and "Tecloc."
Can you tell me what I should pay attention to regarding the breathability of the wind barrier? Do you have any recommendations?
TecLoc
26 May 2026 20:49
The exterior membrane needs a low vapor resistance, ideally around 0.02m to 0.1m (1 to 4 inches). Anything higher doesn’t make sense for your assembly because the OSB on the interior side already provides enough resistance. That’s exactly why the system only works properly when it is vapor-open to the outside and more vapor-tight on the inside. It sounds simple, but surprisingly often it gets done incorrectly.
More important than the last decimal point on the technical data sheet is the installation. Even the best membrane is worthless if the connections, stapling points, and penetrations end up looking like bird nesting spots. This is especially true for Danish summer houses exposed to wind pressure and moisture from all sides.
The Nordland membrane basically fits this requirement. Gutex on the outside also works technically, but only if the entire system is well thought-out, not a mix of board, foil, and “good enough” patches. Many end up creating unnecessarily complicated transitions. For 40m² (430 ft²), you don’t need a high-end wall system from a passive house brochure.
MachsSelbst
26 May 2026 21:59
You gutted the summer house, right? What did you find inside, apart from the mice?
Mold? Rotten wood?
What I want to say is this: The Danes, Swedes, and Norwegians don’t build their holiday homes the way they do without good reason. If their method worked well in the 1970s, why change it?
The typical wall construction is designed for a continuously occupied, heated, and ventilated house. In that case, the costs to make it energy-efficient make sense. But for a cabin used only 4 out of 52 weeks per year, it doesn’t make sense—and can even be counterproductive—to add too much insulation or seal it too tightly.
A silly example: Look at a car. It usually stands outside 24/7, exposed to rain, cold, and heat. It’s heated or cooled at most 1–2 hours per day, if at all. And? It doesn’t develop mold.
A wooden garden shed, unheated, doesn’t get moldy either.
So why insulate a house that you don’t use in winter? The heating would have to run constantly. Who would even check if it’s working? That doesn’t make sense.
