ᐅ Dimensions and Tolerances
Created on: 16 Apr 2009 12:32
calvini
Hello!
Has anyone here ever installed a LUFTIG HOO A00 (stainless steel) under a Faktum extractor hood cabinet with a height of 57 cm (22 inches, FA 337), where (here comes the tricky part) there are additional Faktum wall cabinets with a height of 92 cm (36 inches) attached on both the left and right sides of this setup, so that all cabinets align at the top edge?
I tried this after planning the kitchen this way with the IKEA kitchen planner, and the entire layout was carefully reviewed by an IKEA employee during the purchase. Neither the planner nor the employee mentioned any potential problems in this regard.
I was informed by the planner that the extractor hood must be installed at least 75 cm (30 inches) above the (gas) stove. Both the planner and the IKEA employee advised me to leave some space between the base cabinets on the sides and the wall to allow doors and drawers to open properly.
These were all considerations I had already thought about myself, and none of these caused any issues. What I had not anticipated, however, was that during assembly, a cabinet listed as 60.0 cm (24 inches) wide (also confirmed online in the product details) would mysteriously be narrower than an extractor hood listed as 59.8 cm (23.6 inches) wide.
The difference is about 1 to 2 millimeters, meaning the cabinet is approximately 59.8 cm (23.6 inches) wide, while the extractor hood is about 59.95 cm (23.6 inches) wide. Had I known this beforehand, it might have been possible (though not without some effort and additional work) to insert a 2 mm (0.08 inch) filler piece between the cabinet above the extractor hood and the adjacent wall cabinet, and cover it with white veneer at the front. Not ideal, but at least straight and without gaps.
However, relying on the listed dimensions and assuming I would have been warned of such possible discrepancies, building wall cabinets one after another in an older building with not-so-straight and stable walls leaves you in quite a difficult position when you discover the problem—because there are very few options left to fix it.
That’s unfortunate enough. But what really frustrates me is IKEA’s handling of my complaint. At first, I was told that the cabinet is also only 59.8 cm (23.6 inches) wide (I think I once saw this on a website, but I can’t find the page anymore), and that there are manufacturing tolerances, so I just got unlucky. This was not considered a valid reason for a complaint.
When I objected, after several requests a supervisor was brought in who then gave some interesting arguments like: “No one has ever complained about this before,” “You could have seen at the store that it didn’t fit since everything is already assembled there,” and “There are always tolerances; you should have informed yourself beforehand, now you have to live with it.”
I see basically two possibilities here: Either the extractor hood is indeed always wider than the cabinet, in which case it is quite outrageous that neither the kitchen planner nor the IKEA employee warned me before purchase that the kitchen would end up uneven—and that would certainly justify a complaint, although not an easy one to resolve.
Or I am the only person in the world unfortunate enough to buy a combination of cabinet and extractor hood where the extractor hood is, unusually, wider than the cabinet. That would also justify a complaint but would be easy to fix: return the (exceptionally) wider extractor hood and get a normal one that matches the cabinet width.
Nonetheless, my complaint was still refused as a valid claim. When I then asked at least to be informed where I could have read beforehand that the dimensions provided in the catalog and online are only approximate and can vary by millimeters in either direction, the supervisor told me it was no problem and that they would get back to me shortly.
Apparently, it was not that simple, because on the next call I was told the case had been forwarded to “Sweden” (huh!) and they were waiting for feedback from there. The Swedes were not that quick, so it might take a little while, but someone would get back to me.
In fact, I received another call the very next day. This seemed to be about a different complaint: I had planned to combine the carcass of a tall cabinet (FA 702) with the doors of another (FA 706) and had explicitly said at the store that I wanted to do this to fit a 123 cm (48 inch) high refrigerator with a freezer compartment at the bottom (a 90 cm (36 inch) and 35 cm (14 inch) door, then a 70 cm (28 inch) door on top).
I was then told that the carcasses don’t have fixed shelves (since I thought they did, I wanted the FA 702 with a shelf at 125 cm (49 inches)) and that I could just take the FA 706 since everything was freely combinable. Unfortunately, no one mentioned that the 35 cm (14 inch) door is actually only 34.2 cm (13.5 inches) and the 70 cm (28 inch) door only 69.5 cm (27 inches) high—nor that the hinge holes have different distances to the top/bottom edge on each door.
In other words, nothing is truly freely combinable; only the door order shown in the brochures actually works (70 cm door at the bottom, then the 90 cm one—which really is 90 cm high—and then the 35 cm). Other combinations are possible but create very uneven gaps between the doors that the hinges cannot compensate for.
That’s frustrating, as I was misinformed at time of purchase. But since the combination I planned is not shown anywhere in the brochure, I accept that this was my own mistake and have learned that you can only fully trust the advice of some employees up to the point of unpacking the purchased parts.
I will likely resolve this by positioning the refrigerator at the top, making it easier to reach. Less tall people will then need a small step stool to access the freezer compartment, but I suppose IKEA sells those. And when everything is closed, it will look neat again.
Back to the call—besides confirming that this complaint (70-90-35 vs. 90-35-70) is not a valid reason for a claim (no surprise there), they also mentioned that my complaint about incorrect extractor hood dimensions was not a valid claim either.
Since I wondered whether the claim that the case was forwarded to “Sweden” might have been a tall tale, I made it clear that I was not willing to accept this dismissal. Then a supervisor came on and I could overhear some minutes of research and discussion after the wrong handset was placed near me.
To summarize the following conversation briefly: the supervisor said that the extractor hood is probably always wider than the cabinet (this was also visible in pictures she had), but confirmed that a resulting uneven kitchen is understandably frustrating. We agreed to wait for feedback from “Sweden” (the case had actually been registered in the computer after all), and that someone would contact me again.
I am curious how this will develop and what the “Swedes” will say about this mess. It seems clear to me that there are some information gaps, and I find it very unfortunate that this is being dealt with at my expense. I would greatly appreciate hearing about similar (or differing) experiences and receiving constructive suggestions to solve the extractor hood problem.
chicki
22 Apr 2009 14:22
Hi,
I completely agree, poor service. Well, good luck with the refilling.
