ᐅ Deviation of actual values from planned values
Created on: 13 Jan 2020 16:03
O
Oakland
I’m not sure if this is the right section, but I’ll just post my question here:
What percentage deviation from the planned values should be expected or accepted?
Example: A room is supposed to be 350 cm (11 ft 6 in) wide according to the plan, but it is only 335 cm (11 ft). Would this still be within the tolerance range where nothing can be done?
Yosan
13 Jan 2020 22:37
Oakland schrieb:
According to the plans, a room should be 350 cm (138 inches) wide, but it is only 335 cm (132 inches). Would this still be within the acceptable tolerance?
I’m not sure about the exact legal standards, but that is a huge difference. Everywhere we measured precisely, the masons worked with about 0.5 cm (0.2 inches) accuracy… so it is definitely achievable if they want to. Therefore, I can’t imagine that such a large deviation would still be considered acceptable.
Fuchur
13 Jan 2020 23:47
I didn’t measure every wall in our home, but in the areas where we did, the deviation was generally less than 4mm (0.16 inches), with the largest deviation found being around 6mm (0.24 inches). With the deviations mentioned by the original poster, I would primarily be concerned that the walls might also be out of plumb.
hanse987
13 Jan 2020 23:50
DIN 18202 – Tolerances in Building Construction
The standard that should cover everything.
Vicky Pedia14 Jan 2020 08:52
The allowable tolerances in structural construction are regulated by DIN 18202. Table 1 deals with shell construction tolerances. In your case, a deviation of 16 mm (0.6 inches) is permissible. Now, it should be discussed whether a demolition is proportionate and why the error was not detected during the initial setup.
O
Oakland
14 Jan 2020 11:13
Fuchur schrieb:
Given the deviations mentioned by the original poster, my main concern would be that the walls might also be uneven.
Maybe everything is just scaled down proportionally. That makes me wonder: how much concrete and steel does a structural builder actually save in euros in such a case?
An insider once told me about a large car service center that always adds 100–300 milliliters (3–10 fluid ounces) less oil than specified, depending on the vehicle. With premium oil costing around 30 euros per liter (about $3.50 per quart), this adds up to several thousand euros per year.
Just trouble!
Vicky Pedia14 Jan 2020 13:03
You should take this opportunity to check the exterior dimensions and important interior measurements. Then you can discuss savings, but even more importantly, depreciation. Just get in touch.
