ᐅ Lowering the Schock Nova mirror cabinet
Created on: 12 Sep 2021 18:53
Jayzeeburl
I want to remove the shock mirror cabinet. The older unit is firmly installed. Does anyone know how to unlock the fitting shown in the picture? I have two of these fittings, each located in the upper corners.
Which screw should I loosen first?
Close-up of a metal hinge with warranty card on a door.
Jayzeeburl
17 Sep 2021 19:32
A brief update from my side:
First, loosen the vertical screw, then unscrew the horizontal screw by at least 5 turns. This will slightly release the retaining clip’s hook, allowing the cabinet to be lifted upwards.
I’m not entirely sure if the vertical screw is meant for height adjustment. When loosening it, nothing moved at all—it was still very firmly fixed.
It’s quite a heavy piece... you can’t take it down alone.
Thanks again to everyone 🙂
