ᐅ Damp Walls in a New Basement Build – Construction Execution Error?
Created on: 18 Oct 2018 19:30
Earth2018
I’ll start chronologically:
Background: 3 weeks before day 0, the screed was “laid,” including in the basement.
The basement is a “white tank,” meaning the base slab is waterproof.
Day 0: I notice moisture rising on the plaster in some corners of the basement.
At that time, the plasterers were still fetching water in the basement. The suspicion was therefore a leaking hose or something similar.
Day 1: The underfloor heating is filled with water, so the water cannot be coming from the underfloor heating since it was empty beforehand. The pressure was also constant.
Day 2: The level of moisture on the walls has risen slightly.
Day 5: The underfloor heating is put into operation, including in the basement area with moisture. The hope was that the moisture would decrease due to the warmth.
Day 8: Moisture is still present...
It hasn’t rained since day 0 either...
What do you think? What could this be?
A construction fault? Or does it really take that long for the water to dry?
Corner of a wall with cracks at the lower wall area; black sealing strip on the floor
Close-up of a dusty floor corner with damaged skirting board and dirt on the floor.
Corner area of raw concrete wall and floor; sealing strip at the foot and dust.
Corner area of a concrete wall with dark cracks, dusty floor and a coin as scale
White wall in the corner with a fine, curved line; black cable on the ground.
U
Ulrich Fuckert
19 Oct 2018 19:56
No, this does not mean that water is coming through the concrete slab. It simply means that you have water in the screed insulation layer. This water can also enter, for example, if a lot of water was carried around, allowing it to reach the screed insulation layer through the screed edge strip.
Earth201823 Oct 2018 00:16
Quick update:
A (construction) fan with 70 watts is positioned right in front of the affected area, and the situation has improved.
However, it’s clear that the improvement is temporary when a blower is applied directly. We will continue to wait and hope for the best.
Corner view: white, cracked walls with damp spots on the floor; dark pipe in the corner.
U
Ulrich Fuckert
23 Oct 2018 06:32
The longer moisture remains in the screed insulation layer, the higher the likelihood of mold growth.
schubert7924 Oct 2018 05:32
Don't just work superficially with a dryer!
Earth201824 Oct 2018 08:03
The underfloor heating is running, and I do not plan to reduce heating in the basement in the future either.
Or what would you recommend? A standard construction dryer?
