ᐅ Cracks in the side wall of a mid-terrace house, attic level
Created on: 24 Jul 2021 13:48
HubiTrubi40
HubiTrubi40
24 Jul 2021 13:48
I viewed a quite nice mid-terrace house today. What caught my attention, however, was that on the second floor or attic level there are vertical and horizontal cracks on both sides. The real estate agent said that this is where the masonry meets the concrete roof section and that it can probably just be filled with filler. If that’s the case, it would be fine. Does anyone have an idea if this is a plausible explanation? Thanks and best regards
Hubi
White wall with step-like cracks; sloped roof at top, wooden floor at bottom.
guckuck2
24 Jul 2021 15:59
In principle, the explanation is plausible. Where different building materials meet, there is potential for cracking.
However, that does not necessarily make the statement true.
HubiTrubi40
24 Jul 2021 18:52
Since both side walls are so symmetrical and have such clean edges, I suspect that might be the case. The question is... would that be problematic, or how can you prevent such cracks from reappearing after filling?
Tarnari24 Jul 2021 18:59
Only an expert can probably determine if there is a problem. This (non-problematic) issue can be prevented by using painter’s fleece.
24 Jul 2021 20:59
How old is the house?
Do you want to handle this without professional knowledge, or will you be going through it with someone who knows about these things?
Even in this case, I recommend just asking the neighbors tomorrow about the building’s condition and so on 🙂
HubiTrubi40
24 Jul 2021 21:13
The house was built in 2001. It is solidly constructed. Overall, I think the building method is quite good. The roof also still looks very good. But that is something you would expect after this amount of time. I haven't seen cracks like these before. The real estate agent said he spoke with an architect who suggested that the issue might be at the interface between the masonry and the concrete roof structure. I'm not sure if I should still have an expert inspect it.
