ᐅ Crack in the plaster above the external wall insulation on an older building from 1971
Created on: 1 May 2021 14:36
basti009
Hello, we have an older building from 1970. The facade consists of an external thermal insulation composite system (ETICS) with 5 cm (2 inches) thickness and was repainted in 2014.
Our roof was replaced this year, with insulation that qualifies for a 20 percent subsidy.
After inspecting our garage, I noticed cracks in the facade. From the ground, the facade looks excellent, with no visible dirt or damage.
I have read that if the facade ever needs renovation, it must be upgraded according to the currently valid Energy Saving Ordinance, which would never be cost-effective. Since the facade looks perfect from below, I assumed that if anything, we might only need to repaint it again in 20 years.
What could be the worst-case scenario caused by these cracks? Could this lead to the need for a full facade renovation? Or is it more likely that the long crack, if anything, would require only a partial repair in that specific area?
Is it sufficient to just repair the cracks? Can they be left as they are?
The first two pictures show a long crack, estimated at about 0.3 mm (0.01 inches) wide and 2 meters (6.6 feet) tall. When pressing firmly on the plaster, it appears to be slightly flexible.
The second picture shows finer, shorter cracks. These are only found in the upper part of the facade, but in many places.
There are also a few individual cracks, as seen in the other pictures.
Should I be concerned that eventually everything will have to be replaced according to the Energy Saving Ordinance? Or are the cracks acceptable as they are?
Grau verputzte Wand mit feiner Struktur, kleinem Knopf links und Metallkante unten
Weißer Zollstock mit Messskala, Münze in Öffnung, vor rauer Wand mit Riss.
Rauhe hellgraue Putzwand mit unregelmäßiger Struktur; unten eine weiße Rohrleitung.
Nahaufnahme: Hand hält ein Messlineal an eine rissige weiße Wand, Rissbreite messend.
Außenwand: hellgrauer Putz, Fensterrahmen, dunkler Sockel mit Lüftungsgitter und Kies.
Maßband steht senkrecht an einer rauen Wand, eine Hand hält es, unten liegt Papier mit Text.
Außenwand mit grobem Putz; mittig eine kleine quadratische Wartungsklappe mit Schlitz.
Nida35a1 May 2021 17:03
basti009 schrieb:
Could it cause moisture to penetrate in winter and then damage the plaster due to freezing?
There should be no frost under the insulation. With an outside temperature of -20°C (-4°F), the wall thickness and interior would still be around 20°C (68°F), so there is no frost beneath the insulation.
But enough of the remote diagnosis for now.
Keep the house warm and dry, monitor the situation, and cracks of 0.3mm (0.01 inches) are not visible from outside.
