ᐅ Controlled residential ventilation: enthalpy exchanger or standard heat exchanger
Created on: 15 Apr 2017 22:09
Momad
we are planning to install a Zehnder Q350 for our new build and now we have to decide whether to go with enthalpy recovery or a standard heat exchanger. The question is whether enthalpy recovery can effectively and quickly remove the construction moisture.
The enthalpy option has an additional cost of about €650, and retrofitting it would cost €800. What would you recommend, and does anyone have experience with this?
Thank you!
Thank you!
If you have a mechanical ventilation system with heat and moisture recovery and still see indoor humidity above 70%, then it is either broken or not properly connected... 😉
We also use the Zehnder Q 350 with an enthalpy exchanger, and the indoor humidity is around 45% everywhere in the house. The house is also new; we moved in at the beginning of December. I wouldn’t want it much drier than that.
Our ventilation system runs continuously at about 230 m³/h (135 cfm).
Andreas
Momad schrieb:
What happens if the indoor air humidity stays above 70% for the first two years with enthalpy ventilation? Is there then a risk of mold growth?
Andreas
Bieber081518 Apr 2017 09:21We also installed an enthalpy heat exchanger from the very beginning. Everything works perfectly; I would definitely do it that way again.
