ᐅ Inspection of underfloor heating using a thermal imaging camera—insulation needed?
Created on: 17 May 2016 09:38
fraubauer
Good day.
Is it possible for an inspector to check an already installed underfloor heating system using a thermal imaging camera?
The apartment is new and not yet furnished.
We would like to know exactly where the heating pipes are installed.
Also, can such a camera detect thermal bridges in winter?
It is currently too warm outside.
Or how could these points be checked at this time?
Thank you
Thank you
....My concern was only about a freestanding island, since it has to be firmly anchored to the floor.
....That’s not entirely correct. The island is stable enough due to its own weight. For a depth of 60cm (24 inches), it can be considered. Even with underfloor heating, it’s not a problem because the legs are then glued down. I use adjustable raised floor supports and keep the plastic feet for fixing the toe kicks.
To make underfloor heating visible, I use thermal foil if it’s absolutely necessary to screw something into the floor. So far, everything has worked well.
Sent from my mobile device
Regards, Sigi
Neige schrieb:
That’s not entirely correct. The insulation layer easily supports itself due to its own weight. At a depth of 60cm (24 inches), you might want to reconsider. But even then, underfloor heating is not a problem because the feet are glued in place. For that, I use raised floor supports and keep the plastic feet for attaching the baseboards.
Regards, SigiThat’s EXACTLY how they did it – I believe – in our case. However, the kitchen plan required the recess; maybe it’s because we only have pull-out drawers over a length of 180cm (71 inches)?
U
Ulrich Fuckert17 May 2016 19:38The underfloor heating system can be thermographically inspected at any time of the year. The thermography is performed during the warm-up phase. This means: turn off the underfloor heating one day in advance. On the following day, turn it on again and carry out the thermography. After about 20 minutes, the first heating circuits become visible.
Peanuts7420 May 2016 14:03To return to the original question, I once took some images with a thermal imaging camera myself. Normally, you won’t be able to see the individual heating pipes or how closely they are spaced, because the screed and floor covering heat up and distribute the warmth evenly. However, if there is, for example, no pipe installed under a kitchen unit or similar, you will clearly see or even feel this with the camera, and also when walking barefoot in winter.
