ᐅ Tips for Connecting a Doorbell and Chime
Created on: 1 Feb 2020 14:53
Z
Zaba12
Hi everyone,
I need your help—I think I’m having trouble connecting a doorbell with a chime. I just don’t understand the chime’s instructions. The wiring on the chime and the doorbell is different. Both the transformer, chime, and doorbell are designed for 8–12 V (volts). The transformer is already installed in the control cabinet. Does anyone have an idea how I should wire this from a distance?
The green cable is for the outdoor doorbell. The gray one is for the flush-mounted chime inside.
Black flush-mounted chime 120ws doorbell module with terminals C1/C2, 8-12V AC/DC, CE marking
Hand holding stripped wire end of an insulated cable, visible metal strands.
LED push-button module with multipin connector on black plate; wire connections and instructions visible.
Close-up of green-sheathed cable end with exposed colored wires.
Small GROTHE power supply with 8–12V output and C1/C2 connections, mounted on metal bracket
borderpuschl
3 Feb 2020 09:01
@seat88. You are right. It doesn’t matter. Most (non-electronic) chimes are designed for alternating current. I should have looked at the picture more carefully.
