ᐅ Directing Condensation Water into the Downspout?
Created on: 10 Oct 2020 22:12
hippjoha
hippjoha
10 Oct 2020 22:12
We are going to install a split air conditioning system with two indoor units. We can connect the drainage of the first unit to the sewage system. Unfortunately, the slope for the second unit is too shallow. However, the unit is located quite close to the rain gutter. I could route the drainage through the exterior wall and then directly into the downspout. Is this possible?
Regards and thanks
Hannes
seat8811 Oct 2020 06:01
Possible yes, definitely not permitted.
T_im_Norden
11 Oct 2020 08:40
That is just water, so why should it not be allowed?
hippjoha
11 Oct 2020 08:46
As I have read, it is quite common for condensate from flat roofs to be drained via the outdoor unit, which then ends up in the rain gutter over the flat roof.
wrobel11 Oct 2020 12:08
Hello
This is definitely possible and also permitted.
Alternatively, a small condensate pump is also an option.
Olli
hippjoha
11 Oct 2020 21:10
wrobel schrieb:
That is definitely possible and also allowed.
Olli
My HVAC installer said that he would prefer to avoid the pump if possible, since they tend to be prone to malfunctions. What disadvantages would there be if we vent to the outside?
