On my terrace, there are light-colored concrete slabs from the company Godelmann. Brown stains have formed on the surface due to falling leaves (walnut leaves).
Now I am considering buying the "Godelmann-Kraftreiniger" and then sealing the slabs with "Steinschutz perfekt." How effective are these products, and how long does such a sealant typically last?
MODERATOR15 Aug 2012 19:14The dyes from walnut leaves are highly staining; considering that concrete slabs absorb moisture (including colored moisture), the discoloration may have already penetrated deeply. Just try the cleaning method described— it won’t make things worse.
So this special cleaner from Godelmann is definitely better than doing nothing. Of course, it’s not a long-term solution, but there isn’t anything like it available anywhere else.
I had the same problem, and this helped for the time being. Visually, it looked much better than before. 😉
Hannes1983-123 Nov 2015 13:54I have read the posts here before and also got this special cleaner from Godelmann. I am not completely satisfied, though. I need to look for other options.
