ᐅ Cladding of the entrance platform with an integrated light well below
Created on: 17 May 2022 11:23
ScubaDiver
we are currently planning which surface to use for the concrete entrance platform. Additionally, we intended to cover the sides with palisades. Now we have the problem that the light well connects at a different height. I have attached a few pictures.
Do you have any ideas on what we can do? The palisades obviously cannot be installed on the light well.
I would really appreciate all ideas and suggestions. Why it was done this way should not be part of the discussion, as we are already frustrated enough about that ;-)
Thank you very much
Outdoor area: concrete step in front of a dark front door, mailbox, plant, and wooden pallet
Exterior view of a house: dark front door, wide concrete step, potted plant, and gravel ground
WilderSueden
17 May 2022 14:21
Personally, I would cover the concrete base with decking boards. This is well suited for DIY work and you can easily do this over the light well as well. You just need to make sure that the bottom board doesn’t sit in moisture.
