ᐅ Cladding/Enhancement of a Garden Wall
Created on: 27 Sep 2020 14:34
X
X_SH5_X
I would like to cover or enhance the wall in my garden in some way.
I was thinking about using wall cladding panels, which are available for both interior and exterior use. For the top of the wall, I would need to find a suitable coping slab.
Has anyone done something like this before? It should work similarly on a wall as it does on an interior wall, right?
Steinblockmauer im Garten, Boden mit verstreuten Äpfeln unterschiedlichen Reife.
Ausstellung von Steinverblendern in Beige, Grau und Weiß mit Preisschildern im Baumarkt.
X
X_SH5_X
27 Feb 2022 19:25
I would need to measure, but I estimate it is about 1 meter (3 feet) high.
Yaso2.028 Feb 2022 08:55
X_SH5_X schrieb:
I would need to measure, but I estimate it’s about 1 meter (3 feet) high.
Thanks!
Could you also tell me if you treated the ground beforehand or how you proceeded to ensure everything holds properly?
X
X_SH5_X
7 Mar 2022 15:38
Yaso2.0 schrieb:
Thanks!
Could you also tell me if you treated the substrate beforehand or how you proceeded to make sure everything adheres properly?
Sorry, I just saw your message now. I only primed the substrate with a bonding primer, nothing special. The cladding panels themselves were installed using a tile adhesive from a tiler friend. That’s all there was to it. So far, it’s holding very well. Installing them was a bit tricky because I didn’t want to start from the bottom to avoid cutting pieces at the top. Fortunately, the measurements fit quite well. I nailed a 3m (10 ft) straightedge to the wall and aligned the panels from there up to the top, always two rows stacked. Once those were fixed, I removed the straightedge and continued.
If you have any more questions, feel free to ask.
Yaso2.08 Mar 2022 17:21
X_SH5_X schrieb:
I only primed the surface with a type of bonding primer,
Many thanks!!
I was thinking about having the wall plastered, but if it only requires primer under the cladding, you might be able to skip it every 2 meters (6.5 feet) 😀.. For example, we wanted 2 meters (6.5 feet) of cladding, then 2 meters (6.5 feet) painted white, and alternate like that to create a more varied look. In front of the white walls, large plants, and by the cladding, small flower beds in front..
Our wall is 22 meters (72 feet) wide on one side and another 17 meters (56 feet) on the other..
X
X_SH5_X
8 Mar 2022 17:31
I had also considered something like this, not covering everything completely. It probably looks good as well. Make sure the cladding you choose is suitable for exterior use.
Good luck with that.
11ant8 Mar 2022 18:48
Yaso2.0 schrieb:
For example, we wanted 2 meters (6.5 feet) of cladding, 2 meters (6.5 feet) painted white, alternating to create a varied look. In front of the white walls, large plants, and by the cladding, small flower beds with blossoms.
Our wall is 22 meters (72 feet) wide, plus another 17 meters (56 feet) on the other side.
Keep in mind that breaking it up into sections can actually emphasize the size even more.
