ᐅ Aluminum Carport
Created on: 3 Feb 2016 07:49
daniels87
Hello!
I am currently looking for a carport.
I actually prefer not to use wood since our patio roof is also made of anthracite aluminum.
Several offers for double carports with storage rooms were over €25,000, which seemed too expensive for a first purchase, even though the quality was likely very good.
There are various online suppliers offering relatively simple aluminum carports with polycarbonate twin-wall roofing panels, for example under the name "Verona 5000." However, I’m concerned that these might be a bit too flimsy.
I’ve attached two pictures. One shows a roof connected to the house (the more expensive option) and the other one shows two separate single carports with an inexpensive corrugated metal shed as a bike/storage room.
Option 1 would be nice, but it would nearly use up our entire budget reserve for the house construction. I don’t think much will be left by the time the house is finished anyway. The driveway also needs to be done first, and the patio has priority over the carports.
Or maybe a wooden double carport? I’m not sure if that would suit the house.
Good luck
daniels87
Grundriss Erdgeschoss eines Hauses mit Wohnbereich, Wintergarten, Abstellraum und Doppelcarport.
Moderne weiße Gebäudefassade mit Carport, grauem Kiesweg, Glasfenstern und grünem Garten.
Weiße, zweigeschossige Hausfront mit großen Glasfenstern, gepflastertem Hof und Metallcarport
andimann17 Feb 2016 10:08
@EFHNI
We need 4 m (13 feet) in width and 6 m (20 feet) in length. 7 m (23 feet) wide without a central support beam is quite something—are you planning to fit three cars in there?
That goes beyond the usual standard; I’m not sure if they build something like that. Left-side openings are not preferred here, so I’ll send you the contacts via private message.
Andreas
matte
17 Feb 2016 10:19
I would also be very grateful to receive this PM!
EFHNI17 Feb 2016 19:48
No, only 2 cars are supposed to fit underneath.
Our current carport is 6m (20 feet) wide, which just about allows the doors to open partially on both sides when both cars are parked optimally. (One side is the house wall, the other side is the carport side wall.)
However, if you want to get through between the cars with a bicycle, for example, I find it quite tight.
At 7m (23 feet), it should be much more comfortable.
motox
21 Feb 2016 15:29
@andimann
Instead of a link, you could just mention the provider... that should be allowed... if not, I’ll join the private message as well.
andimann23 Feb 2016 13:29
Hi,
Hopefully, the building expert won’t be too harsh on me...
The companies are
HWG Tech
Myport
Holz-Ziller
Just try searching for them online.
Andreas
motox
23 Feb 2016 18:02
@andimann
Many thanks... I took a screenshot just in case... if a building expert joins the discussion.
