ᐅ Brightly Lighting a Basement with Natural Sunlight | Light Well or Similar Solutions
Created on: 20 Jan 2016 14:22
world-e
world-e
20 Jan 2016 14:22
I am interested in learning about the options for bringing natural sunlight into a basement.
More specifically, my question concerns ways to make window wells brighter than usual or using special window wells. Light wells are unfortunately not possible with these windows. Would it be feasible to install walkable glass panels instead of grates over the window wells? Or is there a way to use something like light tubes or solar light collectors (potentially mountable similarly to a window well and without needing to be fully cast into the basement walls during construction)?
It would be great if anyone has useful insights on this topic or can even recommend specific systems. Thank you very much.
Doc.Schnaggls
20 Jan 2016 14:44
try searching on Google for the "Heliobus Daylight" system.
These are special light shafts from Switzerland that use mirror technology to bring daylight into basement rooms.
A really neat solution, although somewhat expensive...
Regards,
Dirk
merlin83
21 Jan 2016 12:16
Doesn’t that cause glare when the sun shines on it?
Doc.Schnaggls
21 Jan 2016 12:30
Well, I have only seen such a device once as an exhibit at a trade fair – so I can’t answer that with certainty.
However, in my opinion, glare should only occur if the sun is almost directly overhead...
