ᐅ Breaking up a compacted construction access road after new construction – How can I get through?
Created on: 4 Feb 2024 14:10
ShaymiLenny
ShaymiLenny
4 Feb 2024 14:10
We have now been living in our new build for a few weeks and need to soon address the drainage for the driveway and the terrace roof. We already have a plan regarding the soakaways and their positioning, etc.
Eager and enthusiastic, I grabbed a shovel and after about 10cm (4 inches) of soil, I hit a nearly impenetrable layer: For the construction phase, the main contractor created a temporary road for the crane and construction vehicles. As a layperson, I can only guess what this consists of, but it appears to be a very densely compacted mix of large stones, rubble, gravel, and pebbles. When I try to dig in, it feels like I’m hitting solid rock. Unfortunately, I’m not trained to operate an excavator and wanted to use the digging of the pits as a kind of voluntary workout.
How can I get through this heavily compacted gravel layer? Do you have any tips? Or will I need to hire someone with heavy machinery for this? I really wanted to tackle some of the work myself, but I’m not sure if that will be possible.
Any help would be greatly appreciated!
Lenny
Nida35a4 Feb 2024 14:29
Our landscaping contractor had a crowbar about 1.5 meters long (5 feet), one end pointed and the other flat, weighing around 5 kilograms (11 pounds). He used the bar by swinging it down by hand to loosen the compacted material from above, then removed it with a shovel. Ask around the neighborhood for such a bar. The spade is too light and flexes.
jens.knoedel
4 Feb 2024 15:04
A pickaxe can also work wonders.
Question: What areas and depths are involved? Depending on that, a rented mini excavator could be a solution for around 100€ (about $110).
Tolentino4 Feb 2024 15:10
Yeah, a pickaxe for 20 EUR from the hardware store works wonders. Still, it’s tiring.
So, unless you’re dealing with just 1 meter (3 feet) of space between the house and garage or there are cables underneath, I would rent a mini excavator and spend a Saturday digging around. It’s really not rocket science and can even be fun!
ShaymiLenny
4 Feb 2024 15:19
Thank you for your quick responses!
This concerns an area of about 6m by 2m with a depth of approximately 1.70m (5.6 feet). So, quite a bit of soil to move. Basically, I can imagine doing it with a few friends, a crate of beer, and getting started, but maybe that’s a bit too much.
A pickaxe/pry bar is a good idea. I can definitely try that out; this won’t be the only spot in the garden with this issue... 🙂
For a hole of approximately 6m by 2m by 1.70m (5.6 feet) deep, what category of excavator would be needed? A “mini excavator,” or would the bucket not be deep enough to reach 1.7m (5.6 feet)?
Tolentino4 Feb 2024 15:24
At 1.70 m (5 ft 7 in), you’ll need to slope the edges anyway. In that case, you can use a mini excavator. A larger one works faster and is less likely to tip over if you accidentally steer incorrectly.
