ᐅ BEJUBLAD Oven Error Code F111
Created on: 9 Oct 2015 14:38
Dune_8247
Dune_8247
9 Oct 2015 14:38
Hello!
After our move, the oven stopped working.
I can provide the exact appliance model number if needed.
First, I performed a pyrolytic self-cleaning cycle.
The next day, when I tried to preheat the oven, it only heated up to a preset temperature of the core temperature sensor (CTS), even though this sensor was neither connected nor installed.
Unfortunately, I don’t know how to disable this function, as there is no information about it in the manual.
Now, after a few seconds, the error code "F111" appears and the oven switches off.
What does this mean? I couldn’t find anything about it in the manual.
Could it be related to a fuse?
The oven is plugged into a grounded power outlet together with the microwave, both connected to a power strip.
When I connect the oven, these codes appear: F005, then C847, and P022 (with a lock symbol).
I would be very grateful if you could help me so that I can finally use the oven again.
Joel
IKEA-Freund
9 Oct 2015 19:33
the stove is from Electrolux. For other Electrolux appliances, the error code F111 means that the core temperature sensor is not properly connected...
Regards,
IKEA-Freund
Dune_8247
9 Oct 2015 19:42
Hello!
Thank you very much for your reply.
As I understand it, the core temperature sensor is an accessory used to measure the internal temperature of, for example, roasts.
I found a socket in the front left corner that is covered by a small round metal disc (similar to a door peephole). I believe the core temperature sensor is meant to be inserted there.
However, I do not have the core temperature sensor.
At the very back of the oven, there is a metal rod about 5cm (2 inches) long, but this is not the core temperature sensor, right?
How can I resolve this issue?
IKEA-Experte
9 Oct 2015 22:24
Oven plugged into a power strip? That’s never a good idea, especially if you want to avoid any risk of fire.
Unfortunately, the error codes are not published for every model. You have a 5-year warranty on the oven. Contact customer service.
