ᐅ Backflow valve with or without pump
Created on: 6 Jul 2020 17:17
Kuota88
Kuota88
6 Jul 2020 17:17
Our construction company recommends a backwater valve with pump function, Kessel Pumpfix S, due to a slight slope and basement. The cost will be roughly between €4,000 and €5,000.
Alternatively, we could install a standard backwater valve for only a few hundred euros.
What do you think? Are there clear advantages or disadvantages? How do you decide on something like this?
Best regards and many thanks
Vicky Pedia6 Jul 2020 17:48
The requirement for a backwater valve is stated in the official approval for the wastewater connection. This is always necessary when the property is located below the backwater level.
The flap with a pump function ensures drainage during a backwater event. You have to decide whether you can manage without a toilet and shower for a while. Usually, it lasts only a few hours. Another consideration: electrically operated valves rely on power. If the power goes out, they do not close or pump.
I personally have two mechanical backwater valves. In the past 17 years, I have needed them only once.
I hope this helps as a guide for your decision.
pagoni2020
6 Jul 2020 18:13
@Vicky Pedia is correct. A flap is yes, everything else is unnecessary. Many other events are more likely!
Bookstar
6 Jul 2020 19:56
Use a flap valve instead of a pump!
Kuota88
6 Jul 2020 20:08
@Vicky Pedia
Thank you, that is already a good statement.
blackm887 Jul 2020 20:57
We live on a hill; water can only drain away. We have a manual flap (also called a check valve).
