ᐅ Installation of Ikea Faktum tall cabinet with oven does not work
Created on: 4 Aug 2011 22:34
ehrtbbeehreE
ehrtbbeehre4 Aug 2011 22:34Hello,
during the installation of our kitchen, we encountered the following issue: The upper door and the panel above the oven cabinet are so close together after inserting the oven that they rub against each other. Additionally, a metal edge (on the underside of the oven) is rubbing against the lower cabinet door. It somehow seems like the cabinet carcass is about 2 cm (1 inch) too short. We have fully adjusted the hinges, but it still doesn't fit properly. Are we doing something wrong? Unfortunately, the manual provides very little information.
Best regards, ehrtbbeehre
IKEA-Experte4 Aug 2011 23:43Did you select the correct beams in step 7?
ehrtbbeehre5 Aug 2011 13:55Yes, we have that.
Gismospapa4 Sep 2011 22:05Good evening,
did you shorten the fascia (9.4 cm) according to the instructions?
Gismospapa
Gismospapa
ehrtbbeehre11 Dec 2011 11:55The trim is already 9.4cm (3.7 inches). Does anyone else have any ideas? We have now adjusted using the feet, but the upper cabinet door is still not level and rubs against the trim on the right when closing. We have exhausted all adjustment options on the door. The cabinet is standing in water. I’m about to give up =)
Elvis_122011 Dec 2011 12:43Just to be sure, I wanted to follow up on your answer based on Gismospapa’s post...
Have you shortened the side panel or not?
Because for the 217cm (85 inches) cabinet body, the calculation is:
217cm (85 inches) - 57cm (22 inches) (lower door) - 60cm (24 inches) (oven) - 92cm (36 inches) (upper door) = 8cm (3 inches) left for the side panel. (7cm (2.8 inches) would probably also work – this can be adjusted through the gap sizes).
I’m just asking to be certain, because if the side panel has not been shortened, the gap sizes obviously won’t fit.
