ᐅ Is the annual energy consumption of the air-to-water heat pump reasonable?
Created on: 5 Sep 2018 13:23
LincolnHawk86
I just received the bill from the energy provider and wanted to hear your experience and opinion.
House: Solid brick, KfW 70 standard, built 2016
Occupants: 2 adults, 1 toddler
Area: 270 m² (180 m² ground and upper floors, plus 90 m² basement)
Heating: Viessmann Vitocal 300A (13 kW) with underfloor heating
Annual consumption including hot water was 6300 kWh
Do you think this consumption is reasonable?
LincolnHawk86 schrieb:
6300 kWh electricity
Individual room control
Household electricity runs through a separate meter.
Heating element activatedthen check the operating hours of the compressor and the heating element, then you will have your answer.H
HilfeHilfe5 Sep 2018 16:50We don’t know our actual consumption, but we pay 80€ per month for 240 m² (2 units) with 7 people in the house for electricity for the pump. We also have solar thermal collectors on the roof for hot water.
Depending on the conditions, this might not be so unrealistic after all.
Here are a few examples that can lead to high energy consumption:
- Hot water set to 60°C (140°F) with a daily shower of about half an hour
- Heating the basement above 22°C (72°F) (possibly poorly insulated in a KfW70-standard house)
- Poorly adjusted pump
- Individual room control
- No ventilation system, meaning a lot of manual airing
- And so on...
Assuming you have a relatively poor annual efficiency factor (AZ) of 3, you could end up with about 19,000 kWh of heating energy. With high hot water consumption, that’s roughly 12,000 to 13,000 kWh for the house, which might be realistic.
However, if you use water sparingly, set your hot water to 45°C (113°F), don’t heat the basement above 18–19°C (64–66°F), and keep other rooms below 22°C (72°F), the consumption could be considerably lower…
- And so on...
