ᐅ Is the annual energy consumption of the air-to-water heat pump reasonable?
Created on: 5 Sep 2018 13:23
LincolnHawk86
LincolnHawk86
5 Sep 2018 13:23
I just received the bill from the energy provider and wanted to hear your experience and opinion.
House: Solid brick, KfW 70 standard, built 2016
Occupants: 2 adults, 1 toddler
Area: 270 m² (180 m² ground and upper floors, plus 90 m² basement)
Heating: Viessmann Vitocal 300A (13 kW) with underfloor heating
Annual consumption including hot water was 6300 kWh
Do you think this consumption is reasonable?
Bookstar
5 Sep 2018 13:28
That is about 150 euros per month. This is definitely too high. I would estimate it should be at least one third less.
fragg
5 Sep 2018 13:36
LincolnHawk86 schrieb:
Annual consumption including hot water was 6300 kWh (6300 kWh).
kWh electricity? Or kWh heating energy? And with household electricity?
Heating buffer tank and individual room control? Heating element deactivated? Underfloor heating?
LincolnHawk86
5 Sep 2018 13:39
6300 kWh of electricity
Individual room control
Household electricity runs through a separate meter.
Heating element activated
Tommes78
5 Sep 2018 13:45
The question is, when does your heating element turn on? If it is always activated (which doesn’t make sense), then I can understand the consumption; otherwise, I find it too high.
halmi
5 Sep 2018 13:48
It is not possible to make a reasonable assessment like this. If you heat the entire building, including the basement, constantly to 23°C (73°F), the energy consumption might actually be very good.
