ᐅ Aerated concrete 42.5, thermal conductivity (lambda) 0.08 or 0.09 W/m·K
Created on: 11 Dec 2019 07:44
eddy8118
eddy8118
11 Dec 2019 07:44
I hope you can help me. I am trying to decide whether to build my exterior walls with 42.5cm (17 inches) aerated concrete blocks with a lambda value of 0.08 or 0.09.
I am not building to KfW standards, and the heating system is gas combined with solar. Is there a significant difference between the two?
Thanks in advance.
Lumpi_LE
11 Dec 2019 11:00
Approximately 20-30€ difference in heating costs per year
Z
Zaba12
11 Dec 2019 11:04
If you’re not building according to KfW standards, then using a 42cm (16.5 inches) brick doesn’t make any sense at all. But everyone can decide for themselves. I can easily achieve a lambda value of 0.09 or 0.08 with a 36cm (14 inches) brick as well, and that one is also unfilled.
guckuck2
11 Dec 2019 11:15
Aerated concrete 425mm (17 inches) Lambda 0.09 = U-value 0.204
Aerated concrete 425mm (17 inches) Lambda 0.08 = U-value 0.182
Aerated concrete 365mm (14 inches) Lambda 0.09 = U-value 0.237
Aerated concrete 365mm (14 inches) Lambda 0.08 = U-value 0.211
If there is no energy standard requirement to meet, I would skip the upgrade. The additional cost is probably in the four-figure range and not worth it.
However, I would consider going with 365mm (14 inches) masonry. That should be sufficient, especially with Lambda 0.08.
The extra cost for the better block should be offset by the reduced thickness, resulting in thinner walls and therefore more living space.
Lumpi_LE
11 Dec 2019 11:16
Zaba12 schrieb:
If you’re not building according to KfW standards, then the 42 cm (16.5 inches) brick really doesn’t make much sense. But everyone to their own. Because I can easily achieve a lambda value of 0.09 or 0.08 with a 36 cm (14 inches) brick as well, and that one is also unfilled.
Basically, yes, a 42 cm (16.5 inches) brick is not very economical. But lambda is only the thermal conductivity; of course, a 42 cm (16.5 inches) wall with 0.08 W/(m·K) insulates better than a 36 cm (14 inches) wall with 0.08 W/(m·K).
eddy8118
11 Dec 2019 11:35
If there is no energy standard to meet, I would skip the upgrade. The additional costs are probably in the four-digit range. Not worth it.
The extra cost for the better block should be offset by the reduced thickness, resulting in thinner walls and thus more living space.
The additional costs are about 2000€ for our project. Good point. Thanks!
