ᐅ Hot Water Recirculation Line: Is a Check Valve Required?
Created on: 10 Feb 2014 23:01
lubu0815
lubu0815
10 Feb 2014 23:01
Hello experts,
I have a hot water circulation line in my newly built semi-detached house, which I want to circulate only on demand using a Circon circulation control. However, when the pump is off, the return line above the pump still heats up.
The heating engineer believes that the pump must always run, so this problem cannot occur.
I don’t think that makes sense and I believe I’ve heard that a non-return valve is required in the circulation line.
It would be great if someone could clarify what the regulations require here. Thanks!
Wastl
11 Feb 2014 08:44
May I ask if you are achieving a KFW standard? Our builder’s heating technician explained to me that a hot water recirculation pipe would disqualify the project from KFW subsidies. It would be helpful to know if it was possible after all.
Unfortunately, I don’t have a solution for your problem.
nordanney
11 Feb 2014 13:57
A hot water circulation line is nothing special. We have it too, controlled by motion sensors in the bathrooms and by a switch in the kitchen.
The KfW isn’t interested in that either (aside from the fact that they never find out).
klblb
11 Feb 2014 21:54
@nordanney That sounds interesting. May I ask how you wired it electrically? Are there one or two pumps (one for the bathroom circuit, one for the kitchen circuit)?
Thanks and best regards
klblb
nordanney
11 Feb 2014 22:55
@klblb
There is only one pipe, which also has only one pump. The plumber and the electrician have taken care of the details (the rough-in installations have just been completed). I hope everything will work out as planned.
E
Explosiv
12 Feb 2014 17:20
Hi
When I installed the system myself, I planned to use a timer for the circulation pump. Running it continuously is neither necessary nor cost-effective. I installed a check valve in the circulation line.
