ᐅ Experience with roller shutter control using Shelly 2.5?
Created on: 3 Nov 2021 13:36
SamSamSam
First of all, we consciously decided against a full smart home system but would like to be able to control some of our electric roller shutters via smartphone or voice commands. (It was a cost issue, and our general contractor didn’t really have the expertise for it.) I came across the Shelly 2.5 devices.
Are they recommended? Are there better alternatives in the same price range?
Is there anything to consider with traditionally wired roller shutters that have switches at the room entrance? Since our shell construction is still in progress, we could still take some things into account if necessary.
Thanks for any information.
In der Ruine4 Nov 2021 11:20
Stefan001 schrieb:
So with this, there would be no difference anymore (except for the specific operation) between a push button and a switch when used with the Shelly, right?
They have thought of everything at Shelly.
I still think that in this case, push buttons are the nicer solution. Tap up – done. Tap down – done.
The funny changing switch positions would drive my inner perfectionist crazy.
SamSamSam
4 Nov 2021 11:24
In der Ruine schrieb:
The constantly changing switch positions would drive my inner perfectionist crazy.
I would feel the same way.
Is it really the case that without a Shelly device behind the switch it wouldn't work properly? Would you actually have to hold the button down?
In der Ruine4 Nov 2021 11:26
SamSamSam schrieb:
Is it really the case that without a Shelly behind the switch it wouldn't work like that? Would you really have to keep it pressed?
Yes, because the roller shutter motor is simple and only runs when powered. The "convenience" is then handled by the Shelly.
Araknis4 Nov 2021 11:31
The randomly changing switch positions would drive my inner Monk crazy.
I feel you. That’s just not acceptable 😱
SamSamSam schrieb:
Is it really the case that without a Shelly behind the button, it wouldn’t work properly? Would you then really have to hold it down?
Yes. That’s why I mentioned earlier that it’s best to install those devices right away, or later, depending on how perfectionist you are, replace all the switches with push buttons. The operation logic then is long press = move, short press = stop, or if you have roller shutters = stop/louvre adjustment.
barfly666
4 Nov 2021 19:54
What about the Shelly Switch 1? At least that one fits into the electrical box.
Araknis4 Nov 2021 20:49
barfly666 schrieb:
What about the Chelly switch 1? At least the Shelly fits inside the electrical box with that one..
What is the author trying to tell us? The 2.5 is actually even a bit flatter than the 1.
