ᐅ Transition between wood-look tiles and hardwood flooring
Created on: 28 Oct 2021 13:10
JuliaAlex
we are currently choosing tiles for our bathroom and generally like tiles with a wood look very much. However, we want to install a real wood floor outside the bathroom and are now wondering if the transition from the tiles to the wood flooring can look good. We definitely won’t be able to match the exact color tone of the tiles with the wood floor, and are concerned that the transition might look awkward rather than intentional because the wood colors might clash.
Has anyone had experience with this and can tell us if it still looks good or if the transition isn’t very noticeable?
Thank you!
JuliaAlex
28 Oct 2021 20:28
This can be easily avoided by deliberately choosing a clearly different shade; possibly also changing the laying direction. My bigger concerns would be 1. the installation heights of both coverings and 2. the dimensional accuracy of all parties involved at the transition (profile). Maybe @KlaRa can clarify this?
But isn’t this the case with all transitions from the bathroom to the hallway, and also doable there? In this respect, I wouldn’t really have any concerns, since almost no one has a continuous flooring throughout all rooms.
28 Oct 2021 23:29
JuliaAlex schrieb:
Concerns that the transition might look like "trying too hard" because the wood colors clash.
I fully agree with your concerns.
Georgian2019 schrieb:
In the hallway downstairs, we have black and white checkered tiles and parquet in the living room... The transition also doesn't look like "trying too hard."
In this example, nothing clashes.
But when it’s wood next to wood, it doesn’t matter whether it’s tiles in the bathroom and wood in the hallway — it’s about wood next to wood, which is similar in texture, color, or grain.
This “similar” look comes across as cheap.
Choose contrast in the bathroom... there are so many great tiles available, and wood patterns are slowly going out of style.
hampshire
28 Oct 2021 23:44
JuliaAlex schrieb:
We definitely won’t be able to match the tile color exactly with the wooden floor, and now we’re concerned that the transition might look awkward rather than intentional because the wood tones clash.
Your concerns are justified. Besides the color, there is also a tactile difference at the transition that can’t be avoided. It’s okay to make this visible—without creating a huge contrast.
My son insisted on wood-look tiles for his bathroom, and I was persuaded to agree—it is his apartment after all. What always bothers me (just as with laminate and vinyl) are two things that immediately give away the fake:
  • The repetition rate of the grain pattern—I’m a bit obsessive and notice the repeating patterns within seconds.
  • The sensory mismatch between touch and smell.
(I also accepted a fake surface for the kitchen countertop because the overall kitchen design works for me. Admittedly, though, it still doesn’t fully convince me.)
JuliaAlex
29 Oct 2021 08:08
Add some contrast to the bathroom... there are so many great tiles available, and wood grain is slowly going out of style.
We have been considering a lot of options, but unfortunately, we don’t really like many tile designs. I find gray concrete-look tiles throughout the entire bathroom quite cold and monotonous. Sand-colored tiles are warmer, but I don’t think they look particularly modern. Highly patterned small tiles (for example, in the Portuguese style) are quite trendy, at least as accent spots, but that feels too fashionable to me and my husband has vetoed it.
Since our bathroom is only 8 square meters (86 square feet), the tiles shouldn’t be too dark either. Wood-look floor tiles combined with light gray concrete-look wall tiles and a white washbasin with a wooden countertop have been the best solution for us so far to achieve a bright, cozy, and still fairly modern look in the bathroom. But maybe we are missing out on some other great trend...
hampshire schrieb:
What always bothers me with these (just like with laminate and vinyl) are two things that immediately reveal the fake:
  • The repeating pattern – I’m so picky that I notice the repeating motifs within the first seconds.
  • The "misleading" of the sense of touch and smell.
I completely agree that with all fake wood surfaces you should never be tempted to confuse them with real wood. With vinyl and laminate, you usually still have the option to go for real wood – so for me, it would never be an option to use wood-look tiles in the living room, simply because they don’t look like real hardwood flooring. However, in the bathroom, you don’t really have a real wood alternative, although I understand if someone doesn’t like that and prefers to stick with "real" tiles.
Has the transition to the adjoining room worked well for your son?
29 Oct 2021 08:49
JuliaAlex schrieb:
Sand-colored tiles are indeed warmer, but I don’t find them particularly modern.
Well, beige and natural tones have long since replaced the gray trend 😉
JuliaAlex schrieb:
But maybe we are overlooking some other great trend...
Set your own trend!
Reconsider the monotonous light gray on the walls, ... (including your own quote 🙂
JuliaAlex schrieb:
but unfortunately, tile-wise we don’t like that much gray concrete look throughout the bathroom, I find it pretty cold and monotonous.
... and mix it up. There are plenty of alternatives for walls that have stood the test of time beyond trends.
If the bathroom is only 8 sqm (86 sq ft), I would recommend light, subtle colors on the walls, and something more durable on the floor, maybe sandstone-colored, which could then continue up to the shower area or similar.
Retro tiles on the walls, for example, play with shape while the color stays rather understated.
29 Oct 2021 09:02
Take a look at bathroom tiles on Schöner Wohnen’s website. They offer the full range of options, and wood-look and gray tones are only just mentioned briefly there 😉
