we are currently considering how we want/could design the exterior appearance of our house. It starts with a new coat of paint and some minor repairs to the facade and gutter. Then we thought about removing the rough plaster completely and giving the house a smoother (more modern) render. Of course, that changes the cost significantly. The wood in the entrance area and under the roof overhang also needs painting. The question here is whether to keep the natural wood tone or switch to white. Of course, that is all a matter of personal taste...
The appearance of our terrace railing is also a matter of taste. We might have chosen a more subtle design if we had bought it... 😎 It is an aluminum substructure that is basically indestructible. We are still thinking about whether to replace the railing at some point. That’s why everything should look more “harmonious” in the end, if you know what I mean 🙂
When someone from the painting company came to inspect, their first words were definitely to keep the plaster as it is, since you probably won’t find anything easier to maintain, and you can also do a lot with the paint.
Here are photos with the old wooden windows:
The front door will be replaced in a few weeks. The new door is white and features three square glass elements:
Ideas... suggestions... opinions... are welcome 😀
haydee schrieb:
Most likely, the budget made the decisionIn terms of cost, new plaster is roughly three times more expensive than a paint finish.haydee schrieb:
Who even notices which plaster is used? The tiles at the baseboard would bother me more.The “tiles” – more precisely, thin brick slips – could possibly be changed to a gray color instead.Hangman schrieb:
I also wanted to mention the base tiles. Same goes for the railing.
... Mention for what? 🙂
Hangman schrieb:
That’s actually enough – the house has character and is coherent. Exactly! I think you can see that in the first photo with the front view and the old wooden windows. It’s really all a matter of taste. With the new white windows without muntins, we’ve already changed the character somewhat, and ideally, we want to continue that without losing the overall harmony.
The old windows are still visible on the right:
Snowy36 schrieb:
If it had just been built, wow, what a difference that makes visually… I would change the plaster and make everything else gray... What exactly do you mean by “everything else”?
Hm. What I notice is that the windows on the sides are rather simple in white, while those facing the terrace are wooden. Have you also considered those in your planning? Is it meant to stay inconsistent? Personally, I don’t find that a problem, but I might consider painting the divided-light windows.
The plaster still looks quite good. I would not do anything at first—if, upon close inspection, you think it needs painting, then go ahead. But replacing intact, nice plaster with average plaster seems wrong to me.
Neither!
Is it still possible to reorder it? 😉 I hope it is at least made of paintable wood and not plastic.
I’m also a fan of gray. Gray looks subtly modern, but it’s not always the right choice.
If you want a somewhat more modern look, I would suggest:
First of all, replace the plain trellis to the left of the garage with a rectangular one.
Next, I would get rid of the reddish base—give it a dark gray instead.
The railings front and back should be light gray, blending softly with the house, without any “dark accents.” Maybe the handrail in dark gray. The beams of the canopy also in light gray.
And here’s the important part: the front door and the shed should be either deep black or another accent color, otherwise the house ends up as a white-gray uniform look 🙂
Be careful not to strip the house of all its character!
Schimi1791 schrieb:
Here the question is whether to keep the wood tone or to rather go with white. Of course, it’s all a matter of taste ...
Neither!
Schimi1791 schrieb:
The new door is white and has three square glass elements:
Schimi1791 schrieb:
Now, with the new white windows without muntins, we have already somewhat changed the character, and ideally, we want to continue that without losing consistency.
hm. What I notice: the windows are quite simple in white on the sides, and wooden on the terrace side.
Have you considered those as well?
...The windows are uniformly designed all around. There are no wooden windows with muntins anymore. The photo shows a snapshot during the window replacement.
The plaster still looks quite good. I would not do anything initially – if up close it seems it needs painting, then do so. But replacing intact, nice plaster with average plaster, I think that’s wrong.
...Above the left garage, the plaster is quite damaged and is already peeling off. Otherwise, regarding this point, it is fine. Sure, some areas could use a coat of paint. That would be the minimum treatment.
Is it still possible to reorder them? 😉 I hope it’s at least made of paintable wood and not plastic.
...The new door will be aluminum and white. The three glass panels are because we have this design on the interior doors on the ground floor, as I already showed in the house photo thread.
You have to be careful not to strip the house of all its character! That risk exists. That’s why I’m here... 🙂
