The 153/16 is marked with a red outline. So, you can access everything through the driveway, including the access road, wastewater, and other utilities? As long as it is about three meters (10 feet) wide, trucks and fire engines can get through. That should be sufficient.
It’s not clearly visible on the map excerpt, but presumably, the 153/11 mainly serves to provide access to the 453/13 – otherwise, there probably wouldn’t be a garage marked at the upper end.
Scout schrieb:
You can’t really see it in the map excerptThese seem to me to be the key words - the original poster should indicate where more than just the excerpt can be seen (preferably not as a link, since those are probably not welcomed here).https://www.instagram.com/11antgmxde/
