ᐅ Gable windows – we can’t decide.
Created on: 3 Jul 2019 21:12
tumaa
Our shell construction is nearing completion, and we still have the option to redesign the gable window. It costs about €1100 (the first picture), since it is a custom shape. The attic is intended to be converted into living space in the future. We are currently unsure, as option 1 seems a bit expensive (due to the custom shape), but on the other hand, windows are not frequently replaced in the future.
What do you think about the proposals, and could you suggest any other options?
Thank you!
Süd Ansicht eines zweigeschossigen Hauses als Skizze mit Fenstern und Baum
Architektenzeichnung einer Südfassade eines zweigeschossigen Hauses mit Fenstern und Baum rechts.
Architektonische Zeichnung der Südfassade eines zweistöckigen Hauses mit Fenstern
Architektur-Querschnitt eines Hauses mit Dachgeschoss, Treppe, Maßen und Kanalanschluss.
Grundriss eines Apartments: Wohnraum mit Tisch, Bad mit Dusche, Abstellraum; lila Wände.
tumaa
4 Jul 2019 08:15
Lumpi_LE schrieb:
Why have so many different types of windows on one side? To me, all the variations seem too chaotic.
Consider the following:
What do you think?
Sketch-style south elevation of a two-story house with windows and door openings
Lumpi_LE
4 Jul 2019 08:21
I find this more harmonious.
Steffi33
4 Jul 2019 08:49
Is it possible to lower the gable window a bit? That way, it wouldn’t look so cramped against the roof at the top...
tumaa
4 Jul 2019 09:03
Steffi33 schrieb:
Is it possible to position the gable window a bit lower? That way, it won’t look so tightly squeezed against the roof at the top...
They are currently planning it.... my shell construction contractor will then check how much lower it can be positioned.
hemali2003
4 Jul 2019 09:55
What do you think?
I think that is much better!
Tego12
4 Jul 2019 12:54
Much, much better
